08-16-2017, 11:27 AM | #1 |
Discussion; 383 trailer-puller options.
I want to pull a travel trailer. I currently have a 350 with a mild RV cam, low compression, usable power to about 5,000 RPM (my guess). The heaviest thing I pull is a Vermeer chipper (4500 Lbs.) and this truck does so pretty well but I am near sea level relatively flat terrain.
Ever since I read about a 383 cu.in. trailer puller in Moses Ludel's "Chevrolet and GMC Light Truck Owner's Bible" I have been fantasizing about building one, only with Vortec heads and maybe Fuel injection. I would like to hear if any of you guys have a 383 RV type set-up and what your experiences are. I'm not interested in high winding, high compression race engines, but something that finishes up at 4000,maybe 5000, but makes good torque down low. How much do you pull and how well does it perform in any year Chevy truck. Thanks, Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
08-16-2017, 12:38 PM | #2 |
Re: Discussion; 383 trailer-puller options.
I have a mild 383 connected to a SM465, with 3:73 gears. Used it to pull a 27ft travel trailer and to be honest, it never even new the trailer was there. Off the line, in second gear, with the trailer, i was not the guy holding up traffic. On the freeway, with the trailer, i was able to cruise around 3k @ 75 mph and there was still plenty left. How it compares to the 350, not sure towing, but around town performance night and day.
08-16-2017, 01:01 PM | #3 |
I've been looking at the very same thing for my Suburban that has a TBI. Mine is a 1991, so the block is roller ready. I'm looking at 30 over, with compression at or really close to 9-1. The TBI heads are really anemic when it comes to flow, so possibly the vortec heads. Cam I'm settling on the fence about is either a 262 or a 265 roller. Big thing is the computer and the TBI. I've been looking a lot at these guys: http://tbichips.com/?page_id=73 for the mods to the fuel system and the computer.
Or I may just say screw it and put in a stock GenVI big block 454. What are his recommendations? |
08-16-2017, 02:45 PM | #4 | |
08-16-2017, 05:06 PM | #5 |
motor exploder
Though I don't have one, Chevrolet Performance offers the HT383 & HT383e. It's pretty much exactly what you're talking about doing. Roller cam, vortec heads, forged crank and 4 bolt mains. This engine has always interested me. It's been around for quite a while.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
08-16-2017, 06:31 PM | #6 | |
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
08-16-2017, 08:31 PM | #7 |
Petroleum User
I haven't pulled much with older trucks, but the 6.0 liter vortec I had in my 2004 escalade pulled a 7,000 pound loaded car hauler around like it was nothing.
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
08-17-2017, 02:33 AM | #8 |
I wish I had one of those or the thousands needed to upgrade. That 6.0 was something like 345 HP right? The 1969 350 was rated at 200 (Net).
08-17-2017, 02:36 AM | #9 | |
Also , that figure is gross HP which is ok to compare other engines using the same gross figure. The '69 350 was rated 255 HP gross. So I would pick up 68 HP. I would rather build my own I think. Or just pull a smaller trailer!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 08-17-2017 at 03:07 AM. |
08-17-2017, 02:52 AM | #10 | |
The book is from '95 (seems like just the other year). So that was 55 more HP than the stock 350 in 1969 (255 gross, 200 net).
08-17-2017, 06:24 AM | #11 |
Im thinking of doing the same thing. There is a complete write up in Hot Rod magazine March 2002 issue. The issue is available on line cheap, google it. They bought the GM crate truck 383, did multiple tests from stock to semi rough idle. Stock out of the box they had 338hp and 444torque, 431 torque at 2500 rpm, thats a stump puller in my book.
My truck mr.gasket 350, sm465, and 3.73s. I tow a 4500lb air stream trailer. Even with this motor its not to bad, just when pulling up high roads I have to slow down and down shift. |
08-17-2017, 07:55 AM | #12 | |
motor exploder
The HT is the 323hp version, the SP is 435hp and yes, it is over $6k, but it's a 'hot rod' motor.
08-17-2017, 11:07 AM | #13 |
Petroleum User
Seems like there would be a few around or even more modern drivetrains at junkyards via late model wrecks. Take the 4L65 or 4L80 with it
08-17-2017, 11:17 AM | #14 |
I went here; http://www.chevrolet.com/performance/crate-engines
And looked at the HT383 and the HT383E and both have HP peak at 4200, but both are about 6 thou.
08-17-2017, 11:26 AM | #15 |
That would be the way to go. If I could hear it run. A 6.0 and a 4L80 would really make my day.
08-17-2017, 11:35 AM | #16 |
"My truck mr.gasket 350, sm465, and 3.73s. I tow a 4500lb air stream trailer. Even with this motor its not to bad, just when pulling up high roads I have to slow down and down shift. "
Thanks, that is also encouraging. It's the high roads that I want to prepare for. Here out West even a moderate pass crests at 4000+ feet, and the popular Tioga Pass out of Yosemite is 9,945 feet for example. I'd want to stay in 3d gear on most climbs and I know that this current 350 won't do that.
08-17-2017, 02:12 PM | #17 | |
motor exploder
08-17-2017, 03:19 PM | #18 |
You could build a semi-clone of the HT383, start with good core vortec truck engine and piece it together. Pick your roller cam and stroker crank, then put it together over time as $$ allows.
This is the HT383 cam https://www.summitracing.com/parts/n...7395/overview/ If you keep an eye out, you can find them on ebay for under $100
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 08-17-2017 at 03:24 PM. |
08-17-2017, 03:50 PM | #19 |
A set of vortec heads would do wonders for a 350 with torque and hp. If you get a 383 get an internally balanced crankshaft.
08-17-2017, 05:38 PM | #20 |
WorkinLonghorn not sure of the cam, but i do know its an Elgin grind. Most likely a medium version. http://www.elgincams.com/c-che2.html something like a 280/286 with stock rocker ratio. The carb is a 1406, no mods.
