Old 08-17-2017, 04:29 PM   #1
WB72
Before and After
WB72's Avatar
Repairing rusty cab mounts
Just wanted to share how I repaired some rusty mounts on the cheap.
I found 1-1/2" Washers will fit the cab mounts perfectly.
Set the washers in place, tack them, cut both pieces at the same time, insert washer, weld up!
Total cost = <$1.00.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 08-17-2017, 06:58 PM   #2
silverstreak
Re: Repairing rusty cab mounts
Genius! As long as it's the same gauge or thicker metal. Sure beats welding in a solid patch then getting one of those expensive mega dollar 1 1/2" rotabroach bits to drill the hole.
silverstreak is offline   Reply With Quote
Old 08-17-2017, 07:07 PM   #3
WB72
Before and After
WB72's Avatar
Yes the washers are quite thick, Good penetration will keep them there for as long as i will be around.
That is exactly what i was trying to avoid. I'm kinda cheap when i can be.
This could repair could also be done in the frame.
66,000 miles.
Alberta, CANADA
