Old 09-04-2017, 06:54 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
Bench seat track, questions.......
I dropped the bench seat off at the upholster today and I kept the seat tracks so I could "rehab" them before the seat is done.
Inspecting them it seems as a aluminum rivet needs to be removed for them to come apart?
1979 bench going in a 1978 C10
Old 09-04-2017, 07:50 PM   #2
TKCR
TKCR's Avatar
Re: Bench seat track, questions.......
There would be no reason to take them apart. I restore tracks and frames on a regular basis. Just sandblast them, that's all they will need. Blow or rinse them off with water. Repaint and lube, and you have yourself new looking & working tracks. Too bad you didn't' rehab your frame before taking it.
Old 09-04-2017, 08:09 PM   #3
TKCR
TKCR's Avatar
here's a few pics
Old 09-04-2017, 08:12 PM   #4
Warrens69GMC
I was thinking of doing the frame, I had the seat in the bed of the truck as I was cleaning up around the house. I passed by the upholster and he was open, so I dropped it off.
Old 09-04-2017, 08:34 PM   #5
TKCR
TKCR's Avatar
Those frames always have springs that are broke on the ends. The changed the frames right around 80-81
The first 2 pics are your frame, you can see in the 2nd pic, the spring on the end is broke.
Pic #3 is a 81-87 frame. There is a big difference in the frames.
Last pic is the replacement spring. I put 2-3 on each end. If they are not broke, I replace them anyways, because they are notorious for breaking.
Old 09-04-2017, 08:44 PM   #6
Warrens69GMC
Nice job on those seats!!
Old 09-04-2017, 08:44 PM   #7
TKCR
TKCR's Avatar
LMC has those springs. Here's a link, Front Bench Seat Components Item #3
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=72
They fasten to the last spring, the one that goes from front to back of the frame. Use these 3 prong fasteners, 2 per spring. So if you use 2 springs for each end, that's 4 springs and 8 fasteners.
http://www.ebay.com/itm/321277999753?var=510200784460
Old 09-04-2017, 08:45 PM   #8
TKCR
TKCR's Avatar
Thank you!!
Old 09-04-2017, 09:19 PM   #9
Warrens69GMC
what wire do you use to go from the drivers side to the passenger side?
Old 09-04-2017, 09:37 PM   #10
TKCR
TKCR's Avatar
I'm not sure what your asking.
Old 09-04-2017, 09:42 PM   #11
Warrens69GMC
sorry, driver side seat track to passenger side seat track for the forward/rear adjustment.
see it here, going from diver to passenger
http://67-72chevytrucks.com/vboard/s...9&postcount=12
Old 09-04-2017, 09:50 PM   #12
TKCR
TKCR's Avatar
Yours didn't have one? Most of them are still there on the seat.
Old 09-04-2017, 10:11 PM   #13
TKCR
TKCR's Avatar
This is the wire:
http://www.ebay.com/itm/1973-1987-Ch...FZUXFy&vxp=mtr
Old 09-04-2017, 10:57 PM   #14
Warrens69GMC
this one looked like bailing wire...........
P.S. Thank for the link for Ebay!!
Old 09-05-2017, 09:30 AM   #15
Jstock85
Nice work on the seats! I just did some part swapping on a couple seats of my own and it wasn't difficult at all.
Jstock85 is offline   Reply With Quote
Old 01-09-2024, 03:06 PM   #16
BLP1969
On my 1969, the outer perimeter wire is snapped in two pieces, where can I buy the seat part thar I need? I don't want to buy a whole new seat, because I have already bought the cover, foam, ect. to rebuild it.
BLP1969 is offline   Reply With Quote
