Old 09-09-2017, 03:38 PM   #1
Geos 72
Geos 72's Avatar
72 C10 door gaskets
Hello to all, I'm looking for the best set of door gaskets I can find. I'd like to find a set you don't have to glue in but I'm good with either one. Most of all I'd like to be able to close the doors without any trouble. Anyone know where I can get a real nice set? Any help would be appreciated, George
1972 Chevy C10 Cheyenne shortbox/ 350, 3 speed on the floor
Geos 72 is offline   Reply With Quote
Old 09-09-2017, 04:36 PM   #2
68nou1
68nou1's Avatar
Re: 72 C10 door gaskets
I pulled some, that were in good shape, out of the pick-in-pull off of an early 90s Dakota (I think). It was the square body style. Had to trim a little off of where they meet at the bottom, but seem to work pretty well. They just press onto the door seem with no glue.
Chad
'68 Camaro - 408 sbc, Muncie m20, 9' rear, hotchkis supsension (aka Betty)
'72 C10 - pretty much all stock as far as i know, for right now anyways (aka Charlie)
68nou1 is offline   Reply With Quote
Old 09-09-2017, 08:22 PM   #3
Geos 72
Geos 72's Avatar
Thanks 68nou1, that's the type I'd like to get but I was hoping to get a set of new ones. I'll just search around.
Old 09-10-2017, 10:18 AM   #4
68nou1
68nou1's Avatar
No problem. The old glued on gaskets that I had were wasted and needed replacing. I just pulled the Dakota ones from the junk yard to see how they worked. I figured for $5 it was worth a shot. I will be ordering some new ones probably if I get around to painting my truck, but that's a whole other can of worms.
Chad
Old 09-10-2017, 10:42 AM   #5
GR8-68
GR8-68's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=738221
Jeff is a great guy to work with also
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 09-11-2017, 09:30 AM   #6
Geos 72
Geos 72's Avatar
Hello Larry, thanks for that web site. I checked it out and seen the "press on" door seals for my truck. I emailed Jeff and was happy to know he also has a 72 C10 pickup which he put the seals on and said he was very happy with them. They work great and the doors shut good. They are expensive but if they work for my truck (and I can't see why they wouldn't) it's worth the money. Do you know if Jeff accepts returns just in case? I forgot to ask him. Thanks Larry, George
Old 09-12-2017, 11:50 AM   #7
Geos 72
Geos 72's Avatar
I found out Jeff does accept returns but there is a 20% restocking fee. I hope I won't need to return them. We'll see what happens.
