Old 09-10-2017, 06:05 PM   #1
birkinsb
1970 2wd blazer production number
I know that they only produced 985 2wd Blazers in 1970 but was wounder if any of you have an idea of the first 2wd blazer production number that rolled out . I have owned a 70 2wd for about 8 years now and am finally getting around to putting it all back together.I was looking at the vin# and noticed it ends in 106300. I believe that makes it the 6,300 blazer made that year but what was the first 2wd number?
birkinsb is offline   Reply With Quote
Old 09-10-2017, 09:42 PM   #2
broda1
broda1's Avatar
Re: 1970 2wd blazer production number
I don't know but I wouldn't trade mine for anything less rare than an original Yenko!!!!
broda1 is offline   Reply With Quote
Old 09-10-2017, 11:33 PM   #3
birkinsb
For sure 👍🏻. I couldn't imagine there are very many original 1970 2wd still out there .
Old 09-11-2017, 11:01 AM   #4
4oldcars
4oldcars's Avatar
Does 985 include GMC's?
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 09-11-2017, 11:59 AM   #5
birkinsb
Not sure but i would assume there was even less GMC's made. We can turn this into a who has a original 1970 2wd Blazer or Jimmy thread or start a new one?
Maybe include last 5 of vin so we don't get duplicates and some pics of the Blazer or Jimmy.
Old 09-11-2017, 12:49 PM   #6
birkinsb
Here is some pics of how to read your vin# on blazers and Jimmys
Old 09-11-2017, 01:29 PM   #7
smbrouss70
smbrouss70's Avatar
My 1970 2wd Blazer VIN ends with 138946 and has a build date in Dec of 1969 according to the sticker on the driver's door. I always believed that the ending numbers were a sequence for that particular assembly plant, and that included everything that went down that line. Meaning pickups, Blazers, and Suburbans, both 2wd and 4x4. According to production numbers that I have seen they only made 12,512 Blazers in 1970, both 4x4 and 2wd, so obviously they hadn't made 38,946 Blazers by Dec of 1969.
I assume that your Blazer was assembled in St. Louis as I believe they all were until 1972. If so, you have one of the first, if not THE first 2wd Blazer ever made since you have that low of a sequence number! Unfortunately, I don't believe that could ever be proven or disproven due to lack of records from back then.
BTW, we are going to need some pics of said Blazer! Does it still have the SPID on the glovebox door?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-11-2017, 02:50 PM   #8
birkinsb
Good info , Here is a couple pics that i have on my phone. Body currently at the body shop getting painted and frame is headed back over this weekend to put everything back together again. I should have everything somewhere its just a matter of finding it.
Old 09-11-2017, 05:12 PM   #9
Keith Seymore
Keith Seymore's Avatar
You are correct.
VINs do not correlate between final assembly locations. The sequential portion of the VIN (more or less) increments up with the order of build.
Some plants have an accumulator, or body bank, after the body shop (before paint) and after paint (before trim), which allows shuffling the build order based on operator workload or lack of availability of parts. (Can't have too many stick shifts in a row, can't have to many a/c jobs in a row, can't have too many cab running lights in a row, etc).
Fremont is an example of a plant that built straight through (no accumulators). I do not recall if St Louis built straight through or not.
Yep - pure speculation. The only way to know would be to have been standing there when the trucks went by.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-11-2017, 05:35 PM   #10
birkinsb
So I take it they didn't keep good records of what and when something rolled out back then? Does anyone have any info if the 985 includes Jimmys?
Old 09-11-2017, 06:12 PM   #11
birkinsb
1970 Original 2wd blazers and Jimmys still Alive
1. Brikinsb-106300 Blazer
2. smbrouss-138946 Blazer
Old 09-11-2017, 08:57 PM   #12
broda1
broda1's Avatar
3. Broda1 - 187415 Blazer
https://lh3.google.com/u/0/d/0B31qQX...1942-h1412-iv2
Old 09-12-2017, 07:06 AM   #13
Keith Seymore
GM Truck kept good records back then but they burned in a fire.
GM Canada still has good records. If a vehicle was built in Canada or built in the US for Canadian usage then build information can be accessed through GM of Canada vintage vehicle services http://www.vintagevehicleservices.com/options.html
Pontiac Division set the standard in this regard with Pontiac Historic Services. But that was a "happy accident". They were saved primarily as financial records; the fact that they were a boon to enthusiasts was totally unintentional.
Domestic vehicle information can be obtained through the GM Heritage Center, for vehicles starting in 1976 or 1977
http://www.gmmediaarchive.com/?page=1
K
1979-1986
1986 - 2019
Old 09-12-2017, 11:27 AM   #14
birkinsb
Thanks for all the great info. I have started a thread for the list of the 1970 2wd blazers and Jimmys . Hopefully we can get an idea of how many are still out there.
http://67-72chevytrucks.com/vboard/s...d.php?t=746477
Old 09-13-2017, 09:31 PM   #15
Blazer1969
123474
Blazer1969 is offline   Reply With Quote
Old 05-13-2021, 06:12 PM   #16
Tomsjunk
I just found a very nice but apart 2 wheel 1970. Still has original motor seats ect, was a 4 speed but is long gone. So the question is do I restore it back to original with automatic or upgraded to LS? I was looking and really wanting a 4 wheel but guess I'll settle on the 2 wheel drive. Whats everyone's thoughts?
Tomsjunk is offline   Reply With Quote
Old 05-14-2021, 05:36 PM   #17
1rippen6
The demand on blazers is high right now, if you truly want a 4wd buy the 2wd and trade up. The demand for 2wds is even higher, they are converting 4x4s to 2wd all the time. If you buy the 2wd post a trade for 4x4 on Facebook and your phone will blow up, be prepared. If you have a particular color in made just state you are willing to trade for that color. I'm sure you will get you 4x4 and some cash to boot if your lucky!
1rippen6 is offline   Reply With Quote
