Old 09-13-2017, 06:53 PM   #1
Sawlog
1969 12 bolt
Is a 1969 c10 and 1967 c10 12 bolt rear end the same?
Sawlog is offline   Reply With Quote
Old 09-13-2017, 07:33 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1969 12 bolt
Yes, make sure you look at mounts, coil vs leaf!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-13-2017, 07:34 PM   #3
cableguy0
Re: 1969 12 bolt
Yes as long as they are both coil spring or both leaf spring rears. Both coil and leaf rears were available. Coil came stock stock on chevies but leafs were an option. The rears changed halfway through 1970 and the difference is axle length. They will all interchange though.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-13-2017, 09:09 PM   #4
Sawlog
Re: 1969 12 bolt
Ok, thanks. Both are coil. Guy want 350 for it. Thinks it has 373 gear. Comes with brakes and all.
Old 09-13-2017, 09:25 PM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 1969 12 bolt
Yes, they officially went to the wider rear end in 71 although some 70's had the wider rear. 63 thru 70 were 55-1/2" wide housings with 30-1/2" axles. The 71 on had 57" wide housings with 31-5/16" axles...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 09-14-2017, 08:31 PM   #6
Clyde65
Clyde65's Avatar
Re: 1969 12 bolt
71/72 have 5 lugs also!
Clyde65
Rebuild of Clyde
support our troops!
