09-24-2017, 08:22 PM | #1 |
grease for sway bar
I just applied some red Lucas Gear grease on my bushings for my front sway bar. I am not sure it was the right thing to use. Will that work fine or should I apply something else? Also how tight should I torque down the bolts that go through the bushings? It is a 1977 front end with a 77 sway bar.
09-25-2017, 07:31 AM | #2 |
Re: grease for sway bar
All I ever put on mine was a little soapy water when I installed them to make it easier to get them to go together. I just pull my bolts up tight.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
