Old 09-25-2017, 07:31 PM   #1
Mtblack412
Headlight question
I have a 1986 Chevy Fleetside with a 4 headlight setup. My issue is that on low beams my upper lights are illuminated but when I got to high beams only 3 lights light up. The 2 on the left (looking at the grill) and the bottom on the right. The top right doesn't come on even though it does in low beam. I have replaced that headlight thinking that was the problem and it still has the same problem. I just bought the truck and don't know how the 4 light set up should work. Any thoughts?
Mtblack412 is offline   Reply With Quote
Old 09-25-2017, 09:21 PM   #2
Goats86
Re: Headlight question
Check your ground wires
Goats86 is offline   Reply With Quote
Old 09-28-2017, 12:39 AM   #3
Pontiac1976
Pontiac1976's Avatar
Yes grounds for the lights on the rad support, and you headlight plug.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 10-11-2017, 08:43 PM   #4
Mtblack412
I checked the grounds and they were good. Found the problem in a loose connection to the headlight at the plug. The green high beam wire wasn't contacting all the way. Thanks for the advice!!!
Old 10-11-2017, 09:32 PM   #5
sweetk30
sweetk30's Avatar
its that simple stuff that will get you every time.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-14-2017, 07:53 PM   #6
Mtblack412
