10-28-2003, 12:22 PM | #1 |
Rough co. lift 2 or 4
Trying to decide on which rough co. lift kit to get for my 90 full size blazer. I have read on other posts that the rough co. 4" lift is more like a 5-6" lift so does that make the 2" lift a 3.5"????.
Blazer will run 33x12.5x15 bfg tires and will see light trail and mud. Will also be using this as a tow rig for my 21' boat and on special occasion the 57 chevy to the track.
http://members.cardomain.com/chevyjeff 57 2 DOOR HDTP 82 CORVETTE 90 V10 BLAZER 97 REGAL LSR 2100 (BOAT) Last edited by CHEVYJEFF; 10-28-2003 at 12:39 PM. |
10-28-2003, 12:39 PM | #2 |
pic
http://members.cardomain.com/chevyjeff 57 2 DOOR HDTP 82 CORVETTE 90 V10 BLAZER 97 REGAL LSR 2100 (BOAT) |
10-28-2003, 01:03 PM | #3 |
Nice Blazer.
I don't know anything about thoes lift's.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-28-2003, 06:39 PM | #4 |
user # 2756
I heard they live up to their name. Might want to try Tuff country, I know a lot of people here have them and like them.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
10-29-2003, 12:46 AM | #5 |
I just put a Rough Country 6 inch on my 85 and I think its actually about 7 or so. Yes they do ride a little rough but you will get use to it, I like mine and the price was good to. Hope this might help.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
10-29-2003, 03:44 AM | #6 |
I would go with the 4"... Think you will be sorry if ya go with the 2" after its said and done.
10-29-2003, 10:07 AM | #7 |
funny thing is the 4" is cheaper than the 2" lift. My mai concern is with the 4" (actual 5-6) how it will affect the towing charecteristics of the blazer. If a 2" equals out to a 2.5" or 3" that would be perfect. decisions decisions....
10-29-2003, 01:22 PM | #8 |
Not sure that you will get that much lift with a 4 "......
10-29-2003, 03:35 PM | #9 | |
What size tires you running? Sweet, I ordered my 6" rough country monday, should be here this week. Im installing it Saturday and putting on 36x14.50x16's :p
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
10-29-2003, 03:52 PM | #10 |
Workaholic
If it were a pickup I would go with the 4 inch but on a blazer I would stick to the 2 inch lift due to the shorter wheelbase.
Both lift measurements are based on a new 'stock' vehicle. Leaf springs weaken over time so your Blazer may actually sit somewhat lower than it was originally--this makes the lift springs appear to give a larger than advertised lift. Hope this makes sense. I'd also get all new springs and avoid using blocks in the rear. |
10-29-2003, 05:03 PM | #11 |
I read on some other posts on the colrado k5 board that the ride is a lot stiffer when using the lifted springs compared to blocks in the rear. This will be a 90% on road and 10% off road blazer. I think you correct when the advertised lift is related to the original height and mine has sagged over the years.
10-29-2003, 05:32 PM | #12 | |
Spring Comparison Chart
10-30-2003, 04:12 PM | #13 |
Workaholic
The primary reason I suggested new rear springs is to avoid getting the front higher than the rear (looks bad IMO). If it's sitting good now and you put new springs in the front but use a block in the rear there's a chance that this will happen.
10-30-2003, 08:46 PM | #14 |
Big Block Blazer
What size BF Goodrich All Terrains are those on there right now?
/IoWnZa
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
10-30-2003, 09:40 PM | #15 |
33"s you could go with 2"... i run 32"s on my 2wd truck, with stock rear leaves and new HD front coils. 4" would give you room for almost 35"s, might look funny with too much wheel well not enough tire. besides, no more off roading than it will see, you wont need all that flex room. We ran 33"s on our Jeep with only 2.5" lift. never had a problem.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 10-30-2003 at 09:44 PM. |
10-31-2003, 12:51 AM | #16 |
I thought that the used front springs I paired with 4" rear blocks were 4" but they were either 2 to 2-1/2 " springs or 4" springs that sagged. The front of my 71 k10 was lower but didn't look all that bad. The 33x12.5x 15 still had plenty of room. The only problem I had was I had installed a 4" lifted steering arm and the lift wasn't high enough for the steering arm and the steering felt awkward. I didn't want to switch back to the stock steering arm after all that work removing it so I recently installed 4" Tough country front springs I bought from a boardmember. My truck sits pretty level now and the same 33" tires still look the same on the truck.
The only problem after going with with the 4" spring was my front brakelines were fully stretched on turns and I had to replace the brakelines. I also had to relocate the rear parking brake cable/bracket after installing the 4" block. So these are things you might want to check out with your blazer when you go with a 4" lift: Possible steering arm change, longer front brakelines and modifying the parking brake lines. FWIW
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
10-31-2003, 01:35 AM | #17 | |
10-31-2003, 01:38 AM | #18 |
This is what it looked like before the 6 inches, it has 2 inch blocks in the front and back here. That was the main reason for my hurry in getting the 6. Those blocks in the front scared the crap out of me.
10-31-2003, 10:55 AM | #19 |
My web shots page has pics of my 78 before and after my 6" tc. I hate rough they are crap.
http://community.webshots.com/user/alf4444
2011 CCSB GMC 2500HD DMAX 73 GMC 3/4 ton 4x4 96 Chevy 1500 STD Cab Shortbed Z71 Owner of WickedWolfRC.com |
10-31-2003, 11:32 AM | #20 |
so many choices, I have narrowed it down to a 4" lift kit now I only have to decide between rough co. and tuff co. and springs or blocks for the rear. Guess it will be based on how many other testamonials I can find on each set up. Never thought choosing a lif kit would take so much research.
10-31-2003, 11:37 AM | #21 |
I just looked at roughs website to see what they are charging for their 6" lift and it is more than I paid for mine with shocks and the steering arm and extended ss brakelines. Too bad you aren't closer I'd get you the hook up on TC.
11-01-2003, 10:53 AM | #22 |
My Rough Country came with everything including shocks, boots and the steering arm. No it didnt have the brake lines but it did have the brackets to lower the existing ones. I got the kit with the 4 inch blocks and 2 inch helper spings for the back because of low funds at the time, spent to much at the 4x4 jamborie, but am planning on next year rerplacing with new lift springs. The wife said I couldnt spend any more on the truck till after Christmas.
11-14-2003, 09:55 PM | #23 |
Aight, got my 88 Jimmy lifted, heres some before and after pics with 6" lift and 36x14.50's , I think I gained about 8" of lift because I have plenty of room...heck I could fit 38's
11-14-2003, 11:14 PM | #24 |
Sweet, very sweet!!
11-17-2003, 02:37 PM | #25 |
Post Whore
ChevyJeff, I'm very pleased with my Tuff Country springs. Never road in anything with Rough Country springs to compare it to though.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
