Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-11-2017, 07:31 PM   #1
Bennett68C10
Bennett68C10's Avatar
Choppin Block front crossmember/ Porterbuilt Rear Dropmember & Inner Frame Stiffener
Choppin Block front crossmember for 63-72 C10. Includes main crossmember, tubular A-Arms, 73-87 balljoints, LS motor mounts, power rack and pinion steering rack and steering rack hardware, splined front sway bar, KYB shocks, shock brackets, Unisteer 2 joint steering shaft. No bags included.
Sold
Porterbuilt Rear Dropmember for 63-72 C10. Trailing arms and outside mounted bags. Comes with tubular trailing arms, notch bridge with outside mounted bags, bolt in step notches, KYB shocks, Firestone sleeve bags, bag mounts, lower shock mount bar and panhard bar.
Sold
63-72 Porterbuilt Inner Frame Stiffener for 2 piece driveshaft.
Sold
All parts only used for mockup.
Also have the swb frame rails that these parts were mounted on.
$200 for frame rails.
Please check my build thread for more pics.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-13-2017, 09:15 AM   #2
Bennett68C10
Re: Choppin Block front crossmember/ Porterbuilt Rear Dropmember & Inner Frame Stiffe
ttt
Keith
66 Suburban
IG: bennett68c10
Old 10-15-2017, 07:51 PM   #3
Bennett68C10
Choppin Block front kit sold locally pending pickup.
Keith
66 Suburban
IG: bennett68c10
Old 10-22-2017, 08:26 AM   #4
Mack B
Mack B's Avatar
I have some interest in the frame stiffener. My truck won't lay frame, just a mild notch. Do you happen to know if it would work with a one piece shaft in that application? Next question do you have an idea of what shipping would be to 36502?
Mack B is offline   Reply With Quote
Old 10-22-2017, 08:58 AM   #5
Bennett68C10
It should work with a 1 piece driveshaft as well. I can measure the driveshaft opening if you want to know how much room there is top to bottom line of the driveshaft loop. I quoted another member $1,150 shipped in my other thread in the 67-72 parts board and will do the same for you if you want it.
Keith
66 Suburban
IG: bennett68c10
Old 10-22-2017, 09:13 AM   #6
Mack B
Mack B's Avatar
If you don't mind getting that measurement I would appreciate it, to be sure though I'll try contacting porterbuilt tomorrow to see if they have an opinion. In the meantime if you sell it I understand.
Old 10-23-2017, 10:14 AM   #7
Bennett68C10
You would have 5 3/8” from the top bar to the bottom bar in the center and 5” on each side. This is the inside diameter for driveshaft clearance. Sorry I wasn’t able to get you the measurement sooner, I was on the road all day yeasterday and didn’t get back until late.
Keith
66 Suburban
IG: bennett68c10
Old 10-23-2017, 11:12 AM   #8
Mack B
Mack B's Avatar
Unfortunately it's going to be too short an opening for me. Thanks for the effort though and good luck with the sale!
Old 10-23-2017, 07:57 PM   #9
Bennett68C10
No problem, the inner frame stiffener and the rear Dropmember sold locally today.
Keith
66 Suburban
IG: bennett68c10
