Old 10-17-2017, 06:38 PM   #1
the ideaman
the ideaman's Avatar
Oil pressure gauge
How are you guys running the stock mechanical oil pressure gauge with your LS? Pictures? I'm thinking of a braided line off the oil pan blockoff to the pressure gauge.
the ideaman is offline   Reply With Quote
Old 10-17-2017, 07:37 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Oil pressure gauge
I used the autometer adapter and put my mech sender where the LS elec sender goes...at the back of the intake
Old 10-17-2017, 09:38 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I just run a regular plastic gauge line from the blockoff plate, with some nomex shielding where it passes the manifolds. Braided would be great as long as the compression fittings on the gauge accept it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-18-2017, 09:06 AM   #4
JMac11
JMac11's Avatar
Braided line to back of pump, used compression bushing to back of guage. Took about 3 trips to the hardware store. I usually buy premade fuel pressure gauge line kit.
JMac11 is offline   Reply With Quote
Old 10-18-2017, 02:48 PM   #5
Phill0406
Phill0406's Avatar
Same thing I did, no issues. Except getting to it I had to to take the intake off because it was already in the truck.
Phill
68 Anniversary build - LS swap & Porterbuilt
Instagram @fourdoorphill
Phill0406 is offline   Reply With Quote
Old 10-23-2017, 08:32 AM   #6
Green67Stepper
Green67Stepper's Avatar
Same for me as well. Works great.
Green67Stepper is offline   Reply With Quote
Old 10-23-2017, 10:32 AM   #7
Flubyu
Is oil pressure an available parameter to view thru OBD?
Flubyu is offline   Reply With Quote
Old 10-23-2017, 10:36 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Not on GenIII. There is a PID, but its only for warning light status and not a viewable pressure.
I believe on GenIV and after, Oil pressure is a variable value instead of a status, and should be viewable on HP ECM Scanner, a logger, or something like a Scanguage.
Old 10-26-2017, 11:45 PM   #9
'68 C10
Bought the AutoMeter adapter PN#2268 and connected stock spiral tubing.
'68 C10 is offline   Reply With Quote
Old 10-27-2017, 07:33 AM   #10
72MARIO
72MARIO's Avatar
On my suburban I drilled and tapped the 2004 sending unit.
On my truck i used the 2004 sending unit and read my oil pressure thru obd2 module that displays values in my hdx gauges.
I think only the 1999-2002 do not have the ability to read oil pressure thru obd2 becausè there a 1 wire sender
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-27-2017, 09:50 AM   #11
scoot_mcgrute
On my 2002 5.3, I drilled and tapped the factory sending unit for the factory hardline. I tried the banjo fitting adapter that goes between the block and the factory sender off of ebay but all that did was leak like crazy.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 10-27-2017, 09:58 AM   #12
ls1nova71
ls1nova71's Avatar
I've been drilling and tapping the factory senders for years. Way better than a Chinese adapter that may break off in the block. Page 2 post #26. https://ls1tech.com/forums/conversio...-c-10-a-2.html
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-27-2017, 11:05 AM   #13
paul mora
Just above the oil filter ther is a plate that is held on with two nuts you can buy a replace adapter for this with a tap for a oil pressure sending unit or line
Pulatoy
paul mora is offline   Reply With Quote
Old 10-27-2017, 04:28 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have a late 03, 2 wires on the sensor, status light only.
