10-18-2017, 10:45 PM | #1 |
Removing front coil: upper or lower arms?
Lowering 96 shortbed by removing and cutting coil spring. What works better, loosen upper a-arm or lower a-arm? I always struggle trying to re-install coil spring back in position and bolted back up.
10-19-2017, 07:46 PM | #2 |
driving is in my blood
Re: Removing front coil: upper or lower arms?
Lower.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-23-2017, 10:00 PM | #3 |
Thanks. I'll try the lower.
I've been busting the upper ball joint loose to remove the spring. Works good until I have to line the coil up while jacking the lower a-arm up. |
11-01-2017, 12:07 PM | #4 |
Leave the upper, remove lower ball joint...push spindle assembly and upper arm up out of the way, hold with block of wood. Tons of room to play with the spring without having the spindle in the way.
Do you know the trick for breaking the ball joint stud loose ?
1969 Chev C10 1989 Chev R3500 |
11-02-2017, 08:23 PM | #5 |
I leave the spindle nut threaded on some so it don't suddenly separate with the stored energy of the coil. I sit a floor jack under the A-arm, and hit the A-arm near the ball joint with a sledge hammer until it pops loose. I don't use a pickle fork because it will destroy the ball joint boot.
11-02-2017, 08:30 PM | #6 | |
I remove the lower ball joint grease zerk and place the jack right under the joint with the handle 90° to the vehicle. Once the spindle is loose, you can slowly lower the jack to relieve the spring tension. You'll need the truck high enough on stands for the lower arm to travel down at least 10-12".
11-12-2017, 11:52 AM | #7 |
Thanks for the tips.
