10-29-2003, 03:13 AM | #1 |
Member since 2000
Frame flexing
OK i was thinkin on this. I know there has to be flexing in the frame on a turn, Just seem they would with there design(well the way i see it). Would it help to frab up something to go from one side of the frame to the other to keep it from flexing inward or to one side. kinda like tower supports. I know it sounds wierd.....
thanks Alex |
10-29-2003, 05:56 AM | #2 |
have you looked at your frame? there's these little things in there called crossmembers, that do just what you're looking to do.
10-29-2003, 10:53 AM | #3 | |
Member since 2000
10-29-2003, 12:19 PM | #4 |
i'm pickin up wqhat you're throwin down now. why not just box the frame and be done with it? not real sure what "tower supports" are, but boxing the frame has been done a million times, and it works very well.
10-29-2003, 08:33 PM | #5 |
Just keep in mind the added weight. Don't go crazy with the "boxing".
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
10-29-2003, 09:59 PM | #6 |
5-7 dropped 87 CC Dually
Look at the new trucks they use round tubing. Time to get the hole saw out.
I rather be in my 77 Sanger Picklefork Jet Hydro! |
10-30-2003, 01:57 AM | #7 |
belly dragger
Its a blazer its gonna flex I've learned to accept it.
10-30-2003, 02:08 AM | #8 |
Member since 2000
not for the blazer. the blazers already has here plans. This is just crap i think about off hand.
10-30-2003, 03:40 PM | #9 |
F.A.S.T. president
I dont think its needed on a street truck. I would worry about it at a drag strip when you get the slicks to bite and that drive line torque starts looking for another to way to release its energy. I would think thats about the only time you might tweak the frame enough to damage it.
10-30-2003, 05:43 PM | #10 |
Yea... it's called a full roll cage, that'll stiffin it up. It'd be easier than boxing the frame...and you'd have a roll cage.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
11-02-2003, 01:14 PM | #11 |
somebody say frame flexing?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
11-11-2003, 08:48 AM | #12 |
if you wanna stiffen the front end while truning look into the 3 gen camaros. you can get this thing called a wonder bar/ steering brace. it will be too small for trucks i belie but you can get measurements and make one of your own for fairly cheap. i can get a picture of one if it will help
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
