Need shifter collar
Does anyone sell the shift collar on the steering column for a three speed manual?
My 69 GMC has worn so much the pin that holds the shift handle in falls out. Posted via Mobile Device |
![]() Join Date: Oct 2009
Re: Need shifter collar
I don't believe so, believe that's a GM-only thing. But you can post a "want to buy" ad on the parts board or ask someone that is parting out a truck on the parts board.
![]() Join Date: Oct 2010
I may have one. It will be Sunday before I can look.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
Don't know if you got it sorted out yet or not, but my '62 Ranchero had the same issue...if the holes aren't too badly elongated you can drill both the collar and shift lever to the next size roll pin.
My shift lever wasn't thick enough to do that to, so I drilled the collar way oversized and epoxied in some steel "slugs" I cut from steel rod. Then I drilled the steel out to the original size, and used the original roll pin. Note that the roll pin is supposed to "grab" the collar, and not the shift lever.
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
