almost scrap
![]() Join Date: Sep 2009
this post GMC 305 V6 + 2wd 4 speed conversion
For sale is a complete 1969 305 GMC V6 (305E). This engine came in a truck I bought for the manual transmission. This engine is currently not running, but I do plan to work on it to see if it will run. It has a newer fuel pump and alternator on it, along with all the pulleys, exhaust manifolds, motor mounts, bell housing, flywheel, clutch, and pressure plate. The bell housing has the SM420 4 speed bolt pattern, and that is the transmission that I removed from it. I believe this engine to be original as it still has the stamped numbers on the deck surface. This engine will require at minimum, a carb rebuild and spark plug wires (old ones fell apart upon removal) best I can tell. I am now also including the SM420 4 speed, and all of the parts to switch over to a 4 on the floor transmission EXCEPT the pedal assembly. I also have steering wheel (not great shape) and the non-tilt column. What you see in the photos is what you get for $500. This price is firm, I will not accept any lower offers, or trades. Cash only. I can get more photos and answers questions if you have them so please do not hesitate. If you call and are not able to reach me PLEASE leave a message, I get hounded daily with spam calls so I don't always answer, texting also works.
![]() Join Date: Oct 2009
Re: this post GMC 305 V6 + 2wd 4 speed conversion
Where in Indiana Are you located? Are the valve covers included? I am guessing they are but do not see them in the pictures. Thanks
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
#3 | |
almost scrap
Photo below was engine in the truck I took it out of. Not a great shot of the valve covers but they're in pretty good shape. |
almost scrap
$400 Christmas sale. I've had a few other things take priority and I haven't had time to mess with engine.
![]() Join Date: Sep 2008
What was the exhaust like on that truck? Is the y pipe good or did you have to cut it?
almost scrap
they were true duals all the way back, but i cut them a foot or so below the flange so when i got the time to put it on a stand id have something to weld to for exhaust.
Edit: I didnt realize I did not have the exhaust manifolds in the photos. I will get some pics up of them soon. |
Tags |
305, 4 speed, chevy, gmc, sm420 |
