03-20-2002, 05:10 PM | #1 |
Windshield glass and gasket with chrome molding
Just went to have the new glass installed with the new rubber gasket that is new the type that uses the chrome maybe black molding, They were unable to install it without the chrome molding they said.
Where can I get the molding? can the molding be installed after the glass and gasket is in the truck? WHAT IS SOURCE FOR THE MOLDING FOR THE GASKET??? Do you install the glass the same way with the string that I installed the rear window. Sorry about all the questions I first tried to have it done "professionally" now it looks like I will need to do it myself. I had to trailer the truck some 100 miles to just bring it back home. thanks for your help. Ed ke6bnl ------------------ Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed Sorry 50 F1 pu Sorry 63 Ford Econoline pu
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
03-20-2002, 06:36 PM | #2 |
LMC lists the chrome windshield trim for about $60.[repop] Also gaskets. www.lmctruck.com
03-20-2002, 07:24 PM | #3 |
to answer the other ?,the molding has to be in the rubber before the glass is set......69 longhorn.
http://community.webshots.com/user/hotrodhorn |
03-20-2002, 07:50 PM | #4 |
Thanks for the source I sent away for there catalog and go over it. Might be better off getting the gasket without the trim vrs. $60 dollars to add to what we have. Thanks for the promp response. ED ke6bnl
03-20-2002, 07:53 PM | #5 |
Psycho-billy Member
If you go to http://67-72chevytrucks.com/ you will see a list of many parts suppliers.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
03-20-2002, 09:41 PM | #6 |
I put the chrome in after the windshield and gasket was already on the truck. We couldn't make the chrome, gasket, and windshield in together. What we ended up doing was putting little pieces of wood in the chrome trim valley to widen it out. On a sunny day we put the chrome trim in the rubber. Had to use small pics to pull up the rubber to lock in the chrome. I'm sure this wasn't the correct way, but it did work.
------------------ 72K5 CST 350/350/205 Some pictures. some better pictures
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
