Old 11-08-2017, 10:58 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
1973 Sadle tank fuel pump options for FItech?
Helping a friend get ready to install a FItech throttlebody set up on his 1973 SWB 4x4 454 truck. He wants to run in tank fuel pumps. Does he need to get new fuel tanks or switch over to a newer style like the 87 tanks? Any advice on the best way to do this would be appreciated.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 11-08-2017, 11:28 PM   #2
sweetk30
sweetk30's Avatar
Re: 1973 Sadle tank fuel pump options for FItech?
easy is 87 efi tank for swb or lwb as per the vehilce needs .
87 efi sender unit with out pump on it . cheeper this way .
96 c3500 2wd 350 vortec . replacment fuel pump only for this gets you 60-65 psi range . clips on 87 efi sender unit .
and basic factory bolt in job this way .
but early trucks used smaller fuel filler neck hose so be prepared to have possible hose fitment on filler nipple at tank .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-09-2017, 08:13 AM   #3
Tiger Joe
not fitech but we installed a holley sniper (same basic setup) on a 79 c30.
we bought the sniper fuel pump kit, which included a frame mounted pump and a 90 degree return fitting for the tank.
we flushed our tank out really good and drilled a hole for the return, left everything else stock.
no issues
Tiger Joe is offline   Reply With Quote
Old 11-09-2017, 08:31 AM   #4
sweetk30
sweetk30's Avatar
oh ya do NOT do the fitech fuel comand center unit .
tons of problems with them on all the chat forums.
Old 11-09-2017, 11:16 AM   #5
4x4k30
4x4k30's Avatar
you will need to buy new tanks and sending units for a 87 up and use a 96 and up gm fuel pumps to use the in tank pump the 87 tanks and up are baffled different from the 73-86.
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 11-09-2017, 01:25 PM   #6
SunSoaked
SunSoaked's Avatar
Completly disagree. Have installed and used several of them. Use the command center and leave everything else stock.
SunSoaked is offline   Reply With Quote
Old 11-09-2017, 03:03 PM   #7
sweetk30
sweetk30's Avatar
then sir your dam lucky .
Old 11-09-2017, 11:51 PM   #8
SunSoaked
SunSoaked's Avatar
I'm not trying to be a jerk, I'm just saying your comment is completely opposite of my experience. What problem are people experiencing? There is always the Edelbrock version that $100 less without the pretty guages.
Old 11-10-2017, 08:23 AM   #9
Tiger Joe
He’s not wrong on the fuel command center. If you search there are plenty of threads about people have issues with them. Believe they were pushing fuel past thru the vent
Old 11-10-2017, 09:15 AM   #10
SunSoaked
SunSoaked's Avatar
I ran my vent lines back to the tank. Guess that explains why I don't notice it.
Old 11-14-2017, 09:28 AM   #11
lts70
1970 Daily Driver
lts70's Avatar
Thanks for all the response you guys. FItech unit is ordered and tanks and pumps are on their way.
Is there anything that needs to be done with the selector valve for the tanks?
Old 11-14-2017, 09:46 AM   #12
SunSoaked
SunSoaked's Avatar
Keep us posted on the install. Pics, pics $ more pics.
Old 11-14-2017, 10:28 AM   #13
sweetk30
sweetk30's Avatar
the selector valve needs to be rated for the HIGH psi of the system .
i dont know off hand of a valve rated for this .
i am doing left tank as efi tank . and right side storage / transfer tank to left with a pump and switch .
even gm used a transfer pump from extra to main tank factory with a controler box .
Old 11-14-2017, 12:08 PM   #14
Tiger Joe
at a min you would need to look into the TBI year fuel valve, but I'm not sure if they would handle the pressure of modern fuel injection
Old 11-14-2017, 11:22 PM   #15
HotRodfuelhose
Active Member
A lot of guys have been using these. https://www.autozone.com/fuel-delive...?checkfit=true on LS swaps.
You can see a pic of how I did my sending unit to the hose with AN line for my fitech install w/intank pumps. Used ACDelco EP381 it plugs right into the 87 Sending unit.
If you need AN Hose check us out - there are some offers in the vendors section. http://www.hotrodfuelhose.com
Hot Rod Fuel hose
HotRodfuelhose is offline   Reply With Quote
Old 11-14-2017, 11:22 PM   #16
lts70
1970 Daily Driver
lts70's Avatar
What year are you getting the transfer pump parts from? Never ran into one of those setups, how exactly do they work? Does it automatically shut off when the other tank is full?
Old 11-15-2017, 12:49 PM   #17
lts70
1970 Daily Driver
lts70's Avatar
Thanks for the additional information! I got the Delphi version of that AC pump in stock (FE011). And the Napa number for the selection valve is 2-2198 ordered.
Can I use the original in dash switch to run the new selector vvalve?
Old 11-15-2017, 12:52 PM   #18
HotRodfuelhose
Active Member
You will need to get
Fuel selector switch from an 87, replaces existing dash switch (AC Delco p/n D7089C)
Hot Rod Fuel hose
