Old 11-19-2017, 09:00 PM   #1
wpavlis
Non AC heater install help
So I have had my heater out for a while to fix the leaky heater core and to remove the sizable mouse nest within the inside section. I have the inside box restored and installed and tried to test fit the engine side box today. Does anyone have any tips for installing it? I squeezed and twisted it to get it into place, but every time the rubber seal arround the fan inlet would come off. I even glued it on using some weather strip glue I had. Maybe I need some stronger glue? If it matters it's a 68. I have the inner fender completely removed and I did not remove the hood hinge. Thanks!
wpavlis is offline   Reply With Quote
Old 11-19-2017, 11:28 PM   #2
saxart
saxart's Avatar
Re: Non AC heater install help
I had the same issue with mine. Ended up using RVT silicone to hold the gasket to the heater box. Had to be cautious with the pre-clean, and then let it dry overnight, but it held the gasket on just fine.
Best of luck to you.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 11-20-2017, 12:41 AM   #3
wpavlis
Thanks. Did you need to remove the hood hinge? I guess it's time to clean up the leftover residue and try the rtv.
Old 11-20-2017, 10:30 PM   #4
projectking
projectking's Avatar
I use 3m wetherstrip adhesive
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 11-21-2017, 05:15 PM   #5
wpavlis
That is what I used. Maybe I didn't use enough. The first time I tried the rubber ring got kinda folded over. Maybe that broke the bond so it didn't hold the second time I tried. I guess I will just try it again this weekend.
Old 12-17-2017, 11:44 PM   #6
wpavlis
Wanted to say thanks to those who helped me get this done. I looked closer at how I had glued the gasket to the heater box. It looks like it had slipped upward causing it to stick out farther than it should have. I used some scrap plywood I had laying around to fix that issue.
Once the glue set up I tried to install it again. It worked better this time, but I still couldn't get it on. I gave up an loosened the hood hinge so I could get it out of the way. Worked like a charm after that. I should mention that I used 3M strip caulk to seal it to the firewall. That stuff is sticky!
Of course, I scratched it all up due to stubbornly refusing to loosen the hood hinge. As a result I had to mask up the area and apply some spray paint afterwords.
I am amazed at how well the fan works without a huge mouse nest inside it! As a bonus, the cab no longer smells like mouse urine.
Thanks again for the help!
