Old 12-01-2017, 10:22 AM   #1
blazer2007
tailgate hinge repair
I was trying to find some threads on this repair but could only find one that isn,t wrecked by photobucket,any one have some threads they have saved
blazer2007 is offline   Reply With Quote
Old 12-01-2017, 06:10 PM   #2
grillzy
Re: tailgate hinge repair
What type of repair?
grillzy is offline   Reply With Quote
Old 12-01-2017, 08:13 PM   #3
blazer2007
hinge plate in the body of blazer, the normal rusted area in that 4x4 section of sq tubing
Old 12-02-2017, 08:53 AM   #4
grillzy
You need to replace this rear bed support. The outer 12" will be rotted away and most likely the bed will be soft in spots too. Drill out spot welds in bed, remove the 4 bolts in the end of the bed support at the rear fender underside if they still exist, must remove body mount nuts, lift body off frame high enough to remove and replace with new bed support. Spot weld back into place. Good time to replace body mounts too.
