12-12-2017, 12:07 PM | #1 |
Replacing U-Joints, new ones don't fit?!
Popped out my u-joints using the hammer, wood block, impact socket and drift method (on the concrete floor.
New U-joints are the right part number, dimensional - look to be the exact same size but upon installation (using my bench vice), the damn clips wont go in on both sides, and when I get them both in, the U-joint is so tight it won't pivot. I didn't have to beat it up much to get the joints out, could it have pinced the driveshaft????
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-12-2017, 12:25 PM | #2 |
Re: Replacing U-Joints, new ones don't fit?!
The yoke could be a little pinched, no biggie, get both snap rings in then support both of the cups not in the shaft, rap on the shaft to beat the cup into the clip, turn over do the same to the other side, the joint should move freely, the cup will probably be pushing out the middle of the clip, no worries there either.
12-12-2017, 12:27 PM | #3 | |
12-12-2017, 03:01 PM | #4 |
Too much grease added in cups?
12-12-2017, 03:31 PM | #5 |
The yoke may be slightly compressed when you installed the joint . Try to spread your yoke a little.
12-12-2017, 04:28 PM | #6 |
One of the needle bearings fall out of a cap and end up stuck between the end of the trunion and inside end of cap? This will keep the cap from fully seating on the trunion.
12-12-2017, 04:31 PM | #7 |
Location: Formerly MD and San Diego, now loving life in Arizona
I did this on an '83 Chevy truck that had used some sort of liquid plastic to hold the joints in place. Used a hydraulic press instead of the hammer method though and ruined my driveshaft. didn't realize any damage had occurred until I got the truck finished and hit the highway transferring to a new Air Force base. Couldn't do over 50mph as the balance on the driveshaft was so bad it was shaking the truck terribly. I wish you the best and hope there is no lasting damage or balance issues.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
12-12-2017, 05:02 PM | #8 |
I second checking the needle bearings. When I ended up with tight ujoint after installing the clips. A few whacks with a hammer on the ears usually backed the ujoint cups out enough for clearance.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-12-2017, 06:05 PM | #9 |
Or inexpensive chinese u-joints.
They can be slightly oversized. I found this out more than once. I stick with spicer brand when I can.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
12-12-2017, 06:25 PM | #10 |
This is probably the answer to your question. Had this experience with a 2007 Dodge truck. The new joint crosses were Chinese made, too long, and I had to grind a bit off the ends so that the caps would seat and joint go together. If your needles are in there properly and one or more have not fallen down, measure the lengths of removed vs. replacement. Yes, good idea to stay with Spicer.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
