Old 12-12-2017, 02:05 PM   #1
Keystone_Hate
Accelerator cable bracket?
I searched through a lot of throttle cable bracket threads and have seen a lot of use of aftermarket style brackets. I was wondering if anyone has used a bracket off a GM car? I found this for a 69-72 Chevelle with a small block. GM #3992376
It looks like it’ll work for 72 truck with a small block. I have a manual trans so I don’t need the TV cable bracket. Anybody ever use one?
Keystone_Hate is offline   Reply With Quote
Old 12-12-2017, 02:19 PM   #2
demian5
demian5's Avatar
Re: Accelerator cable bracket?
That could work as long as you have the grommet style cable attachment. It can be a trial and error deal. Try coming up with a pretty return spring setup for an Edelbrock!
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-21-2017, 01:23 PM   #3
Keystone_Hate
Update: Just got this in the mail from Original Parts group. It will work well on a edlebrock carb. I had to file a little notch to fit around the casting on the base of the carb but the notch also acts to keep this bracket in place. In case anyone is looking to use this.
Old 12-21-2017, 11:49 PM   #4
chevykevy
chevykevy's Avatar
Cool, how about some pictures? I was thinking of using the same bracket
chevykevy is offline   Reply With Quote
Old 12-22-2017, 08:08 AM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Its not an Edelbrock carb but the same set up will work. I used a Spectre spring anchor as well as a GM 1972 throttle cable bracket, it came off the factory cast iron intake for the C/10 . and here one with the Carter AFB carb,
If you run your springs toward the front of the motor they equalize the strain on the throttle shaft in the carb causing less wear and prolonging the life of the carb casting.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 12-22-2017, 11:43 AM   #6
Keystone_Hate
Man I never thought about that. That is a good point. Thanks Ironangel.
Old 12-22-2017, 02:29 PM   #7
Keystone_Hate
Here’s some pictures
Old 12-22-2017, 02:30 PM   #8
Keystone_Hate
Sorry for em bein cock eyed. Cell phone upload. Just tilt yer head.
