12-17-2017, 07:03 PM | #1 |
700r4 starter question
Hey guys my first post on here. I need some help, I have a 67 c10 stock 283. Was a 3 on the tree. I purchased a 700r4 from monster. So far everything has went smooth. I went to parts store and bought a starter for an automatic truck they gave me part number R713240B I get it home it doesn't fit, the outside hits the flexplate. My question is what starter do I need or did they give me the wrong starter? I have a 168 tooth flexplate if that makes a difference. Thanks in advance.
Jamie |
12-17-2017, 07:15 PM | #2 |
Re: 700r4 starter question
Lots of different starters out there. The nose of the starter is the problem I'm guessing. Ran into this on my camaro. Took the starter that came with my car to a shop that rebuilds them. When it came time to install it same problem. Luckily enough I figured out what nose I needed and they looked around in there shop and found one. Cost an extra 20.00 but I was glad I didn't have to start over with a complete different starter
12-17-2017, 07:19 PM | #3 |
Should work if using same housing and 168 tooth wheel
Stan 67 swb BLU MULE posted via flip-fone |
12-17-2017, 07:22 PM | #4 |
Yes your right the nose is hitting the flywheel
12-17-2017, 07:24 PM | #5 |
Not sure what you mean same housing and flywheel. This was a manual im putting a 700r4 in
12-17-2017, 11:02 PM | #6 |
Simple, you were given a stater for a 153 tooth flexplate. Get a proper hi-torque unit for a 168 tooth. Notice the staggered mounting holes,your oreily unit has them straight across.
I believe this one is correct for you. ACDELCO 3371016 |
12-17-2017, 11:04 PM | #7 |
Yes sir u are correct, I just stumbled across this like 15 minutes ago. I need a starter with the stargered bolt holes
12-17-2017, 11:33 PM | #8 |
At the body shop.
ACDELCO Part # 3371022 one of these will work great
" That didnt make it any newer " " Dont antique the equipment " |
