Old 12-18-2017, 05:42 PM   #1
miller6t9
miller6t9's Avatar
a very specific question about screws/bolts
does anyone know the size or where I can find the size of the screws/bolts that hold the washer fluid jug bracket on a '72?
miller6t9 is offline   Reply With Quote
Old 12-18-2017, 07:07 PM   #2
toolboxchev
Re: a very specific question about screws/bolts
Check ACE Hardware on that, 100% of what is on our trucks is SAE standard sizing.
If that does not work pull a bolt from around the area under the hood that looks to be the same in size, fit it to the missing area, then take it to the hardware store for a duplicate or shorter/longer appropriate size.
I would bet its a 7/16 or 1/2 inch with 16 to 20 threads per inch.
toolboxchev is offline   Reply With Quote
Old 12-19-2017, 11:45 AM   #3
dfwright
dfwright's Avatar
Just looking at the pictures of mine, they look like 5/16-12 hex washer head screws. I would have to go pull one to be sure, though.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 12-19-2017, 01:06 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
3/8 FLANGE TAP SCREWS 1/4 x 1/2 - Heads are recessed. Same as the ground strap/rear marker ground screws, only coated.
1/4 x 5/8 works.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
