Old 12-18-2017, 11:31 PM   #1
mab67chev
67 Chev 6 lug to 5 lug
What is involved with installing A arms and disc brake spindles from a 1971 c10 on a 1967 c10, what other parts will have to be changed? I also have the complete rear end from the 1971 c10 that I want to install.
mab67chev is offline   Reply With Quote
Old 12-19-2017, 12:16 AM   #2
Robznob11
Robznob11's Avatar
Re: 67 Chev 6 lug to 5 lug
Just swap the whole front suspension you can keep the x member. If you dont have the a arms and draglink you will need to change the ball jts and you will need a custom adjuster and tierod set up. I Have this set up in like new condition i would make you a smokin deal on if you need to go that route. Im going to go completely custom with a bump steer kit now that I modified my track width and geometry.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
