![]() Join Date: Jan 2016
Boss 338 wheels don't fit
I just did a front disc brake job with new rotors after installing the drop spindles. It all went well until I tried to put my Boss 338 wheels back on. I then noticed the hubs on the new rotors are not tapered like the ones I took off. I went back to the parts store to see if they gave me the wrong rotors but they said what they sold me is correct for a ’72 disc brake setup. I had an old rotor with me and they said it looks like someone machined them to fit the wheels! Close look at it and you could see the work that had been done. When I got home I searched this board and sure enough several people said they did exactly that, one even posted a picture of what he had done. Thank you to everyone that posted the “fix” for Boss 338 wheels, it does take a load off my mind. This board is awesome. Now where is my grinder and flapper disc?!?!?!
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
Old member
Yepper's you got to get the grinder out and fix it!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Boss 338 wheels don't fit
not sure you could get the parts store you bought them from to help you out but if you had access to a brake lathe you could chuck them up in it and set it up I the drum mode so it moves the cutting bit in the right direction and cut a little off the nose of it that way.
#4 | |
Old member
I have actually thought about running a small spacer on my front wheels so I could run the newer Chevy center caps on the wheels. It wouldn't take much of a spacer.
