12-20-2017, 03:10 PM | #1 |
Steering linkage geometry
Ok guys I need some help. From the search results found I'm thinking you guys are the ones to ask. I have a 1950 truck. But I took the front suspension off a 1984 c10. Search results found that you guys like to update to the c10 front suspension. Am I right?
Problem is setting up linkage. I made templates off donor, marked my frame, installed the goodies... But I think I made a mistake. The pitman arm will contact the frame. I need some advice on setting up the steering...
1950 Build |
12-20-2017, 05:51 PM | #2 |
Post Whore
Re: Steering linkage geometry
got any pics?
12-20-2017, 08:15 PM | #3 |
Im gonna need to remove fenders for this I think. Only a few bolts though. So pictures arnt great, gear is hanging a lol.
You can see idler, it'll hit but it is a tad lower than the pitman arm the pitman arm is a lot higher. Anyways, I'm thinking I maybe got templates to high. I used 1/4 board, and matched the crossmember holes to the the new holes drilled and marked from there. So I'm not sure how I managed it but I'm hoping maybe I can just go lower. I really want to get angles and stuff right though... and what distance from what should drag link be, should it be parallel with the ground perfectly..
1950 Build |
12-21-2017, 06:40 PM | #4 |
Thread got moved. Now I know about this little subcategory though.
Ok this is what I got at the moment. I still have donor frame... I got it level and checked a couple of things. When level the idler arm should be at about a 55 degree angle... you guys agree? So i checked my truck, took fenders off to get in there better, I got 53-54 degrees. So I'm thinking maybe I'm just too high? Perhaps I can keep the angle but just go down far enough for clearance?
1950 Build |
12-23-2017, 09:52 PM | #5 |
I asked the same question to the 73-87 c10 guys and I forgot to update here.
My concern is just how close is the linkage supposed to be to the crossmember itself. With some small adjustments my pitman arm will clear. I went off the holes on the donor frame... But I just seem real close. Is this normal or should I pull the linkage forward? I'm one pic you can see the tip of my finger... it's a tight fit.
1950 Build |
