Old 12-22-2017, 10:46 AM   #1
jfnar
Front sway bar connection
My 68 gmc needs all the rubber parts on the bottom side replaced. I looked in the LMC catalog and the front sway bar picture shows 4 bushings, all the same part number. My truck has two of those bushings but on the ends it has a different type of connection. I'll attempt to attach a picture. I'm looking for a source for those parts and also curious why my truck doesn't match the catalog. Does it have the wrong parts on it? Thanks for any information you can provide.
jfnar is offline   Reply With Quote
Old 12-22-2017, 10:57 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Front sway bar connection
Your truck has the wrong sway bar.
Here is what you should have. However I used an aftermarket set of urethane bushings.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-22-2017, 11:12 AM   #3
jfnar
It looks like I've got something like this:
https://www.performanceonline.com/19...ormance-Front/
Old 12-22-2017, 11:20 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Here ya go..
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-22-2017, 11:29 AM   #5
Grumpy old man
Grumpy old man's Avatar
You have an aftermarket sway bar , go to the suspension area of this forum and you'll find more info .
http://www.classicperform.com/Store/...ck/6372SBK.htm
Grumpy old man is offline   Reply With Quote
