Old 12-31-2017, 11:38 AM   #1
ChevyC201972
Help with replacing door latch on 72 C20
I am replacing the driver side door latch on my 1972 C20 and could use some advice. I am having trouble with loosening the 3 bolts that hold the latch - I have used PB plaster and everything else I can think of and they will not break free- my next option is to drill them out but I am worried that may create a problem when putting in the new latch. Also the space is very tight and I am concerned about getting the door handle and lock assembly all hooked backed up correctly on the new latch. Any advice on the best way to approach this project is much appreciated.
ChevyC201972 is offline   Reply With Quote
Old 12-31-2017, 05:58 PM   #2
Redneck Rydes
Redneck Rydes's Avatar
Re: Help with replacing door latch on 72 C20
Give them a smack with a hammer,that should loosen them up
Redneck Rydes is offline   Reply With Quote
Old 12-31-2017, 06:27 PM   #3
frogsmakr
frogsmakr's Avatar
Use a hand Impact. The kind you hit with a hammer.
frogsmakr is offline   Reply With Quote
Old 12-31-2017, 06:56 PM   #4
rockyrivermark
Not sure if your repainting or not
If so a little heat works wonders.
Even a bit with propane
rockyrivermark is offline   Reply With Quote
