A-pillar problems? Help please.
So I've been fighting this area in my truck. What your looking at is the drivers lower a pillar. I'm thinking that the a pillar has twisted somehow. Has anyone else experienced this? I'm thinking the pillar should rest flat on the inner rocker.
All about them K’s
![]() Join Date: Jun 2014
Re: A-pillar problems? Help please.
Will the bolts pull it tight? Looks to me like they would.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Has the lower section of the pillar been replaced? How much of the outer floor has been replaced? Looks like it should draw up with the bolts as mentioned already.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
The gap is like 1/2" I bolted some metal & tried to twist it. Didn't work so well. I guess I'll weld it up & try to bolt it back together. Thanks for the help.
![]() ![]() Join Date: Sep 2008
I think I would bolt it together before I did any welding.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
laying low
![]() Join Date: Mar 2001
If it doesn't fit right adjust it until it does before any welding happens.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Somebody please correct if i'm wrong but doesn't the rocker panel go over the A pilar where yo have the three spot welds? Might be why its seems twisted, because your forcing it outwards. just a thought.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
Looks like those welds have minimal penetration. Low setting and thick wire?
#9 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
Got catch on the welds. That particular piece with the welds is not welded in place. That is the lower kick panel replacement piece. I haven't welded anything in yet. I'm trying to test fit everything before welding. I don't have the brace replaced yet so I can't bolt it up just yet. I can tell you that I bolted a piece of 1/4" bar to the lower post & tried to twist it back into submission, but the whole post moved. I'm going to try to bolt it in & then twist it. The whole thing is I don't remember anything being twisted when I took it apart.
