Old 01-02-2018, 11:19 AM   #1
ron lechman
68 C10 Converting to power steering
I have a 68 C10 V8 that I would like to convert to power steering.
My truck currently has the original manual steering it came with. It was a 250 six cylinder standard shift truck now a 305 AT.
i have a good power steering pump that I`ve already mounted.
I have a good power steering box from a 73 - 78 C10 that I have not mounted yet.
My questions are:
Can I reuse my original manual steering parts such as the pitman arm, the idler arm and the center link.
If not what if any parts can I reuse.
I`m tired of the armstrong steering during parking.
Cheers!! Ron
ron lechman is offline   Reply With Quote
Old 01-02-2018, 12:22 PM   #2
FL71C10
Re: 68 C10 Converting to power steering
My understanding is that you will need a new pitman arm, and maybe a new rag joint. I believe the center link is OK.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 01-02-2018, 12:55 PM   #3
ron lechman
Thanks for the info FL71C10.
Cheers!! Ron
Old 01-02-2018, 02:39 PM   #4
Robznob11
Robznob11's Avatar
This is correct!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 01-02-2018, 02:59 PM   #5
dell72
I did the same I-6 to V-8 conversion on my 69 C-10 and I converted to power steering at the same time. I used a steering box from an 87 C-10 and I used a pitman arm for a 69 C-10 with power steering and a rag joint to fit the 87 donor vehicle.
dell72 is offline   Reply With Quote
Old 01-03-2018, 11:29 AM   #6
ron lechman
Thanks for the info guys.
Now it's time I install the power steering.
Cheers!! Ron
