01-03-2018, 01:01 PM | #1 |
Is a notch needed to sit level on bags
I have tried searching but have not had much luck. I have 2.5" drop spindles in the front with plates and cups for the bags. In the rear I am doing bags on trailing arms in the stock spring location.
Will I need to notch the rear so that it sits level aired out? If so how much? Not trying to lay frame just want it to sit level. |
01-03-2018, 01:25 PM | #2 |
Re: Is a notch needed to sit level on bags
When aired out, the front will sit lower even with a notch in the rear. You might as well go ahead and put in a notch. Any standard notch will do as they are as deep as you can go before the center of the rearend hits the bedfloor.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
03-04-2018, 10:34 AM | #3 |
X2...notch the rear and if the suspension is configured correctly the truck should lay out level, unless the rwar driveline doesn't clear the crossmembers or lthe tunnel of the cab.
