Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-11-2018, 07:54 PM   #1
Jrainman
Jrainman's Avatar
Went out for a little AIR today
been so cold and snowy finaly got the 68 out and picked up this little gem up I saw on CL for cheep. 1977 kellogg 80 gallon 2 stage . will be hooking it up in the Am any advice on what maintenace should be done before start up . I plan on changing oil and air filter and just giving it a general going over as far as nut and bolts and electrical components. any advice or insight on old air compressors would be helpful
Jrainman is offline   Reply With Quote
Old 01-15-2018, 07:46 PM   #2
Dead Parrot
Re: Went out for a little AIR today
Do your best to inspect the inside of the tank for rust. Don't want to launch your compressor though the roof. Double check how the motor is wired, 240 v 120. Might put a new belt on the list. Make sure the cut off switch cuts it off.
Dead Parrot is offline   Reply With Quote
Old 01-17-2018, 01:06 AM   #3
BIGglaSS
BIGglaSS's Avatar
Excellent find. Kelloggs are beasts. Slow and quiet. I regret selling my last one. A new pressure relief valve is also a good idea.
BIGglaSS is offline   Reply With Quote
Old 01-18-2018, 09:02 PM   #4
ray_mcavoy
Yup ... I've got an old 1956 Kellogg compressor in my garage. It has a 1725 RPM motor so it runs at about half the speed of many other compressors that have 3450 RPM motors. Mine has been very reliable and trouble free although I did have to put some new valves in the head about 15 years ago. If I remember correctly, I purchased the head overhaul kit from http://www.aircompeq.com/kakits.html
ray_mcavoy is offline   Reply With Quote
