Old 11-02-2003, 04:54 PM   #1
pickup6772
pickup6772's Avatar
Question Seville Rear Disc Swap
HEY GUYS! I HAVE A CHANCE TO PICK UP A '79 CADDY SEVILLE REAR END WITH THE DISC BRAKE SETUP, AND WAS WONDERING IF I CAN ADAPT THIS TO MY '71 C-10 2WD REAR. THEY BOTH HAVE THE 5 ON 5 PATTERN, AND LOOKS LIKE IT MIGHT BE A FAIRLY STRAIGHT FORWARD SWAP. ANY INFO, AND THOUGHTS WOULD BE APPRECIATED.
THANKS, MIKE
MIKE
'67 C/10 2WD LWB
'89 MERCURY GRAND MARQUIS LS
COUNTRY TILL THE DAY I DIE
pickup6772 is offline   Reply With Quote
Old 11-03-2003, 12:44 AM   #2
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
yup! bolt them on. you will need a disc-disc master cylinder too.
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 11-03-2003, 10:54 AM   #3
slam33
slam33's Avatar
If there anything like my 77 Seville set up, you will have to redrill the backing plate/mounting plate bolt patten and you will need to turn down the axle flange to fit into the hats. Mine is the 12" vented setup
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 11-03-2003, 01:40 PM   #4
toytruck
toytruck's Avatar
I forgot about the flanges. Yes, you might have to turn them down.
Old 11-03-2003, 02:46 PM   #5
pickup6772
pickup6772's Avatar
I FIGURED AS MUCH. BUT I HAVE TO PULL THE AXLES TO MOUNT EVERYTHING ANYWAY, SO I'LL SEND THEM OUT WHILE I'M MOUNTING THE BACKING PLATES, ETC.
MIKE
'67 C/10 2WD LWB
Old 11-04-2003, 10:33 AM   #6
slam33
slam33's Avatar
The truck shop in Orange has the masters and the prop valve
</A>
