Old 01-19-2018, 12:09 AM   #1
RedRider
RedRider's Avatar
Split heater core housing - worth fixing?
Took it off this evening in hopes of cleaning out the rats nest inside. To my surprise, it came out in TWO pieces!
So is it worth fixing? maybe JB welded together?
Or should I start from scratch at the junkyard?...trying to figure out my options at this point.
Looks like someone tried to fix it at some point so I don't think it was my fault.
1970 C-10 "Old Yeller"
RedRider is offline   Reply With Quote
Old 01-19-2018, 12:13 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Split heater core housing - worth fixing?
Not too expensive. As hard as it is to get to I would replace it. I got my A/C unit with a heater core and evaporator for $30 at the junk yard. Only one I've seen in 5 years though.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-19-2018, 04:34 AM   #3
rockyrivermark
Keep your eye on Craigslist. You can often find people parting out a c10 and prob get it for pretty cheap I would imagine
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 01-19-2018, 02:12 PM   #4
RedRider
RedRider's Avatar
I'll keep my eyes open for a replacement, thanks. Is there a quick, easy way to check if the blower motor works?
Old 01-19-2018, 02:18 PM   #5
rockyrivermark
You mean the one you have or the parts find?
You can change over your blower motor to the new housing.
To check the blower motor simply ground the housing to the battery ground and touch a test lead wire from battery postive to positive wire connector on the blower.
I recently replaced mine. They are only $25
RRM
My build page
Old 01-19-2018, 02:36 PM   #6
demian5
demian5's Avatar
Tremaynes trucks in north county from you in Poway. Look them up, tell them OC_SS sent you. On instagram you can find him too. Great dude.
https://www.facebook.com/Tremaynes-T...6272889092508/
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-19-2018, 08:29 PM   #7
bill3rail
bill3rail's Avatar
A bit of a hike from you, but they are showing one for $35.00
Catalina Auto Recyclers USA-AZ(Tucson) Request_Quote 800-842-7862 / 520-574-0555
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 01-19-2018, 09:09 PM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Mine was busted pretty much in the same place. I repaired it using a simple fiberglass repair kit like this one. https://www.amazon.com/3M-420-Fiberg...ass+repair+kit
Looking back, I wish I had taken the time to form an insulated lap joint at the narrow center to ease changing or cleaning the fan or heater core without taking the whole unit apart. Fiberglass repair is quite easy and a very durable quick and permanent fix...PS The black wire to ground, the spade terminal to 12 volts. If the fan spins it's good...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-20-2018, 09:55 AM   #9
Smitty
Smitty's Avatar
Have two of the A/C ones laying in the back yard!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is online now   Reply With Quote
Old 01-20-2018, 12:27 PM   #10
RedRider
RedRider's Avatar
Of course you do! How hard is it to use an a/c box for a non-a/c truck?
Old 01-20-2018, 12:34 PM   #11
Grumpy old man
Grumpy old man's Avatar
They are 2 different animals , I probably have a few if you can't find one out your way .
Grumpy old man is offline   Reply With Quote
