01-25-2018, 12:04 AM | #1 |
Corvette filterm/regulator fitting help
Hey guys, starting the process of building my fuel line and I'm running into an issue. I've purchased a couple different quick connect fittings for the return/supply side of the regulator and both seam to be too wide and hit each other when I'm mocking them up.
Here is the parts I have -Napa gold 3737 fuel regulator/filter -Fragola 491990-BL and 491989-BL -Faster -6AN 5/16 and 3/8" threaded quick connect's I liked the idea of the fast threaded fitting but they are in a bind to get them on. So ordered the fragolas thinking they would be thinner (strike 2) same size outer diameter if not bigger then the fast fittings. I'm wondering if any of you have a part number for a 6AN fittings for the 3/8" and 5/16" that will work for the vette filter/reg and not interfere with each other? Driving me crazy trying to resolve the dilemma. Any input is greatly appreciated. Thanks, Curt
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
01-25-2018, 12:33 AM | #2 |
Re: Corvette filterm/regulator fitting help
The fix that i believe would work (have not done it personally) is get a late 90's corvette engine braided stainless fuel disconnect lines for the fuel rail. The supply is 3/8th and return is 5/16th, and should slip on the filter. I think this pair is about 14" long and run about $30.00. With this pair installed on the filter reg, you can terminate how you wish and where you wish on the other end.
When i did my ls i formed all of my lines with my mastercool hydraulic former, and used inverted flair connections as needed. This former can make inverted flair, push connect, and o'ring style ends. I'm running a return style fuel lines with a supply and return at the engine as per 2000 silverado and a gm fuel filter (no regulator). |
01-25-2018, 12:57 AM | #3 | |
01-25-2018, 01:20 AM | #4 |
Post Whore
theres basically little to no pressure on the return side..it just dumps back into the tank with no restriction...i used a -an to 1/4npt and then a hose barb then rubber fuel line and clamps to tank...I don't recall having any issues...I may have bent the inlet side out a little...cant remember... but it is close...I used wix....which one are you using?
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-25-2018 at 04:07 AM. |
01-25-2018, 03:43 AM | #5 |
Mine did the same thing with Russel fittings. I think I just slightly pulled the two lines apart putting a slight bend on the outer line and that allowed the fittings to slide on. I would put the middle one on first and then the outer. This might sound crazy but the bend is very little and never had a problem. I’ll see if I can find a photo.
01-25-2018, 04:10 AM | #6 |
Some photos<a href="http://s1055.photobucket.com/user/Daaaanz67/media/0ad89ceb.jpg.html" target="_blank"><img src="http://i1055.photobucket.com/albums/s501/Daaaanz67/0ad89ceb.jpg" border="0" alt=" photo 0ad89ceb.jpg"></a>
01-25-2018, 04:14 AM | #7 |
01-25-2018, 04:16 AM | #8 |
01-25-2018, 05:07 AM | #9 |
Post Whore
photosucket is no good for posting pics....cant see-um
01-25-2018, 07:07 AM | #10 |
He's got a NAPA. Should be identical to the WIX since WIX makes the NAPA stuff.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
01-25-2018, 07:50 AM | #11 |
Looks like Russel fittings are what most are using . Must be smaller in diameter .
640863 5/16 640940 3/8 I think they also make it with the push on with the metal cap as well . More secure than the plastic locks Here you go . I found them . This is what summit uses on the Wix filter 644110 644120 Last edited by homemade87; 01-25-2018 at 08:30 AM. |
01-25-2018, 12:07 PM | #12 |
meowMEOWmeowMEOW
Get a browser add-on. We posted about this in the big Photobucket threads in the general section. We can't fix the service, but we can fix our own access to it.
Photobucket Embedded Image Fix 0.6
01-25-2018, 12:13 PM | #13 | |
meowMEOWmeowMEOW
In my personal experience, my return fitting popped off while leaving a gas station resulting in a huge puddle of fuel leaking and trailing from my truck back to the gas station (~300ft), and pumping the return fuel onto my headers. I got lucky and my motor was cold after a rest stop, but if the headers had a chance to get warm, I would have been a fireball. If you want the plastic ones, you can have my old ones at your own risk. The second series fixed the issue with the screw on metal retainer.
01-25-2018, 08:08 PM | #14 |
Well this stinks with photo bucket , I haven’t posted any pictures in a while. No to good with computers and was posting pics with my I pad. I’m not real sure what a browser add on is and if it’s compatible with an I pad. I read the thread in the general section but still don’t understand it please help.
01-25-2018, 08:21 PM | #15 | |
01-25-2018, 08:39 PM | #16 | ||
01-25-2018, 08:46 PM | #17 |
Perfect it will work fine, mine has for the last 6 years. That’s how mine looks.
01-25-2018, 08:55 PM | #18 |
If I was to bend one I would bent the outside connection . The one in the middle ( 5/16 ) has a diaphragm behind it and could obscure the pressure . The 3/8 one is only attached to the housing .
Not my picture but one I had found a while back . Last edited by homemade87; 01-25-2018 at 09:04 PM. |
01-25-2018, 10:22 PM | #19 |
Post Whore
dont feel bad daaanz...im no computer man either..ive also read that stuff on the fix but still don't understand it either..
im with homemade87...if your gonna tweak a fitting it needs to be the inlet...pretty sure that's what I did on mine...
01-25-2018, 10:31 PM | #20 | |
meowMEOWmeowMEOW
Its no more than a few clicks, and solves the photobucket issue.
01-26-2018, 12:31 AM | #21 |
Alright, 3/8" side as advised is bent and both fittings clear. When in doubt get the bigger hammer out I appreciate everyones advise on this. Thanks, Curt
01-31-2018, 04:33 PM | #22 | |
02-01-2018, 02:05 AM | #23 | |
Do you happen to have the part number for this tool? sounds pretty dang awesome and useful for LS swap stuff. TIA -Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
02-01-2018, 03:34 AM | #24 |
Post Whore
try this izzy...https://www.mastercool.com/product/7...ring-tool-set/
02-01-2018, 04:29 AM | #25 |
That flaring tool makes flaring lines a breeze! I got mine at Tooltipia.com, it's about the cheapest place to get one, its still not cheap, but worth it if you do a lot of flaring.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
