Old 01-30-2018, 05:09 PM   #1
Marshall50
Heating wiring question
Hey guys, brand new to the forum. I've read many threads but can't seem to find what I'm looking for. Hoping someone can help me out.
I have a 79 K10 with a new 3 speed heater only fan selector. I recently swapped out the heater only box with an ac/heater box that someone donated. I don't care about the ac right now but only want the heater and defroster to work right now. Here's the problem I have... the fan selector is 3 wire and the resistor is 4 wire. First of all is this even possible to use the non a/c selector switch? I don't want to have to buy another new switch just yet unless I know for sure I will want ac in the future. Currently, I only have the blower motor working when the key is on and the selector switch is on hi. There is nothing on the 1st two speeds. Any help is appreciated.
Marshall50 is offline   Reply With Quote
Old 01-30-2018, 06:08 PM   #2
Bandit130
Bandit130's Avatar
Re: Heating wiring question
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 01-30-2018, 06:57 PM   #3
hatzie
Moderator
hatzie's Avatar
You can run the non AC resistor and heater control with the heater sub-harness.
AC uses a relay to run the blower at full speed without melting the switch. You'll need to retrofit the AC wiring and relay along with the AC controls.
How are you handling the firewall ducting differences?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-30-2018, 07:08 PM   #4
Marshall50
Thanks for your response Hatzie!
That might be a hurdle I have yet to come to. I got the switch to operate correctly. Turn the key on, the blower motor comes on. I also got the blower motor to increase with the selector switch fan speeds respectively. I'm not using the number 4 connector on the resistor. I have hot air but I'm concerned the resistor might heat up to much. Is that possible?
Old 01-30-2018, 07:37 PM   #5
hatzie
Moderator
hatzie's Avatar
You should have airflow over it with the blower on. Not sure whether you'll get in trouble without...
air conditioning, blower motor, heater, resistor, wiring
