01-31-2018, 08:13 PM | #1 |
Easily Identify Square Bodies
Here is a picture I created to easily identify the difference between the 73-87 trucks. Hope this helps you all. Thanks
01-31-2018, 08:14 PM | #2 |
Re: Easily Identify Square Bodies
Pic:
01-31-2018, 10:18 PM | #3 |
Do you have a link or pdf file for this? would like to see larger pic but can't on this one.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
02-01-2018, 04:12 AM | #4 |
Pic is too small - resolution not high enough to see much detail.
77 Chevy K20 Longbed 86 GMC C3500 Dually 07 Silverado 2500HD All standard cabs |
02-01-2018, 09:27 AM | #5 |
I'm not saying you didn't create these, but I've seen these before. Here's a link to full sized versions. Found them through a Google image search.
GMC Chevrolet
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread Last edited by hewittca; 02-01-2018 at 09:33 AM. |
02-01-2018, 09:32 AM | #6 |
There's also this one illustrated by Thom Taylor. He did a similar one for 67-72 trucks.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
02-01-2018, 01:32 PM | #7 |
What about the 1-ton C10???
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
02-01-2018, 08:49 PM | #8 |
I can try emailing it to anyone who wants it to see if it will come out bigger; on my computer the width is about 1300 pixels to give you an idea about the size.
I should've said that I "photoshopped" it; it was two separate pictures, and I put the two together (I hated flipping from one pic to the other). The one-tons are listed; the (88) is for crew cabs, and the 1989 is for them also. The (90-91) means that the blazers, jimmys, and suburbans went until 91 with that style grille. Thanks |
