02-24-2018, 11:10 AM | #1 |
Headlight dimmer switch
My headlights only work when high beam is on (68 c10 truck), so I replaced dimmer switch hoping that might fix the problem. Did not fix the problem. Truck has been a work in progress for over 2 years and has the same headlights as when I bought it 2 1/2 years ago so not sure if they even worked at that time. If high-beams work, would that alleviate a wiring issue? Could both headlights possibly be bad? I know very little about wiring, so not sure how to rule out wiring issue. Thanks
02-24-2018, 11:38 AM | #2 |
Re: Headlight dimmer switch
Get a test light & start traceing. Check the connector on the dimmer switch. They are known to corrode in the harsh invirenment they are in. It is very possible both bulbs are burned out on low beam.
George |
02-24-2018, 06:01 PM | #3 |
Post Whore
As Wrenchbender said the dimmer switch wiring is problematic. I had a similar issue with my Burban. A PO had cut the plug off the wiring to the switch and replaced it with slide terminals. I replaced them and the switch as they were a little crusty and when I tried removing them from the switch one of the lugs broke. All was repaired I though but nope! Still had intermittent lights. I ended up finding a splice in the wiring about a foot from the switch that was also bad. So everytime I kicked that spot it would affect the lights.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-24-2018, 10:26 PM | #4 |
Old member
First thing is to check the lights them self. Take the connection loose at the lights. Put your test light in one fitting and see if it lights up. Then hit the dimmer switch see if it goes out. Then put the test light on the other side and see if it works. If both works then the light is burnt out.
If one doesn't work then go to the dimmer switch and try it out the same way. You could have a bad splice some where in between the light and dimmer if both of them checkout ok. Also check the grounds beside the head lights and clean them good.
02-26-2018, 11:37 PM | #5 |
I used to have this problem a lot before I rewired the whole truck. The right headlight is worried through the left headlight. If the connection in the left headlight is bad, both lights go out, food for thought.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
02-26-2018, 11:41 PM | #6 |
Yes, im pretty sure its the wiring. Went to trouble shoot and headlights were working .... now brake lights aren't. Just old wiring and need to break down and rewire the whole truck I guess.
