Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-04-2018, 02:07 PM   #1
pwdcougar
pwdcougar's Avatar
Priming over original paint
Not wanting to have to sandblast, strip or sand the original paint on the roof of my 70 suburban. This is what the paint looks like when sanding with 180 grit sandpaper. It is getting what looks like a pitting effect in the primer. Any thoughts on what I should do?
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 03-04-2018, 02:56 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Priming over original paint
just guessing, but it looks like the primer was really ruff under the paint and when you sanded it you took the paint off the high spots of the primer....
im sure the paint gurus will step in and answer better than me ,but id sand the paint/primer off and start with clean metal
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-04-2018, 09:00 PM   #3
Foot Stomper
Foot Stomper's Avatar
The top left area in the second picture looks good. No more sanding required there. No need to remove all the paint to bare steel unless it's falling off. The little spots look like it is falling off so more sanding is required in those areas.
You want a "tightly adhered surface" to apply primer to.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 03-05-2018, 09:59 AM   #4
MP&C
MP&C's Avatar
Looking at left picture, the small spots in the grey ?? through to the red oxide appear to be delamination in those spots. Looking toward the lower left corner of the same picture, you appear to have the same delamination spots from the red oxide to the bare steel. How do you know when the issue will stop? I would err on the side of caution here, much easier and cheaper to strip to bare metal now than after your fresh paint starts delaminating as well.
Robert
MP&C is offline   Reply With Quote
Old 03-09-2018, 08:29 PM   #5
pwdcougar
pwdcougar's Avatar
In the first picture the white area is where there is a low spot in the metal. It is the original white paint on the roof (this truck was gold with a white painted top). The area just below that spot is where I sanded through the white and the gold paint. The roof paint is nice and smooth but where I sand it the gold seems to flake off in tiny spots. The spots circled in red below show where the gold is flaking off leaving pits.
Looks like I'm going to have to sand down the entire roof down to bare metal. That's going to have to wait for better weather. We got 22 inches of snow earlier this week in NJ.
Thanks for the responses guys!
Paul
Old 03-10-2018, 10:40 AM   #6
Foot Stomper
It looks to me like you'll have to sand the whole roof. You can leave the white paint (low area) alone if you like.
It's not important to strip every panel of all coatings when painting but in this case, I'd agree that the previous coating has failed, and therefore must be removed.
