03-05-2018, 01:07 PM | #1 |
[noob with a deadline] engine wiring
Hey guys, I am trying to get my truck running by spring break to get it out of my house cause I am renting my house out. When I bought my 1963 chevy c-10 there was no wiring in the engine bay at all. I pulled the original 283 and put a 350 in out of a 67, but now I need to wire everything up and don't know what to do!. Help!!. Is there a wiring harness for us to buy online or will we have to jerry-rig something up?
Luke |
03-05-2018, 01:32 PM | #2 | |
Junior Member
Re: [noob with a deadline] engine wiring
03-05-2018, 04:20 PM | #3 |
I agree with gizmoduck, I've got the American Autowire complete update kit. It has everything you will need, and great instructions. Each individual wiring phase is bagged separately with instructions.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
03-05-2018, 07:26 PM | #4 |
Another option:
http://www.wiringharness.com/ |
03-05-2018, 08:11 PM | #5 |
And then there is the wire with the two alligator clips and the screw driver. It will get it to run. Are the plugs still in the firewall? There are engine harnesses available. In the FAQ section there are links to the wiring diagrams so you can evaluate what you have still in the truck.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
03-05-2018, 09:53 PM | #6 |
Yeah, how much does it need to move? How far? With about 20' of wire you can have it running.
03-06-2018, 12:40 PM | #7 |
just down the driveway and around the corner!
03-06-2018, 01:53 PM | #8 |
Is it HEI? One power wire to the dist./ coil. Battery to the starter. You can use a remote trigger from the parts store for to start it. That will get you down the road.
Negative battery cable to the block Positive battery cable to the starter solenoid Wire with a pushbutton from +12V to the S terminal of the starter solenoid (or a remote starter button if you have one) Wire with a toggle switch from +12V to the BATT terminal of the HEI. Or you could just twist the wires together. Not that I've done that. |
Tags |
1963, 1967, 350, chevy, small block |
