Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-11-2018, 03:06 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
01 Blazer Fuel Injection Spider
This Blazer has 110,000 miles and it died in traffic the other day. Now its not starting, but it tries.
I tested the fuel pump, replaced filter and have 50psi fuel pressure. When you try and start it, you get a strong smell from the tail pipe.
Is there a way to test this FI spider?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-11-2018, 03:43 PM   #2
61_FL_Apache
Who Me?
Re: 01 Blazer Fuel Injection Spider
Just to add something, I did pull one plug and it was dry, but smelled strong of gas.
Steve
2001 Blazer 4D 2WD
Old 03-11-2018, 07:09 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
Fuel pressue should be 60-66 psi.
Check for spark at all cylinders. Distributor caps are really common on these.
95 S_Trucker is offline   Reply With Quote
Old 03-16-2018, 04:09 PM   #4
61_FL_Apache
Who Me?
I replaced the spider and that solved the issue.
Steve
2001 Blazer 4D 2WD
Old 06-06-2018, 11:46 PM   #5
CastIron
CastIron's Avatar
I'm curious.... did you have the original style poppet injectors and replace them with the updated style? How hard was the job?
I have a 2000 blazer that I don't know what it has for injectors.
CastIron is offline   Reply With Quote
Old 12-14-2018, 08:17 PM   #6
61_FL_Apache
Who Me?
Sorry for not replying sooner, I didnt know your message was here. I was searching for another issue on the Blazer and saw your post.
The job was pretty easy. I did the same thing on my 97 Tahoe which is the same thing with two more cylinders. I went with the updated style and did the same on the Tahoe. I did see a performance increase on the Tahoe, but couldn't really tell on the Blazer. The hardest part was taking the fuel lines off at the back of the engine. Other than that, just watch what goes where. I used some tie straps to keep the wire harness out of the way. There are other components attached to the manifold so watch for those.
Feel free to PM me if you need more info.
Steve
2001 Blazer 4D 2WD
