Old 03-12-2018, 11:00 AM   #1
threeonthetree
threeonthetree's Avatar
71-72 center link 1/2, 3/4 ton difference?
I ordered a used 71-72 center link for a 3/4 c20. I thought it was gonna work but looks totally different, the eBay seller will return only for the cost of the part. But I am looking at getting one but need to know if there is a difference.
The are listing them all the same at this link
http://67-72chevytrucks.com/vboard/s...d.php?t=456889
Centerlink:
Grouped by Differences:
*60-62
*63-64
*65-70
*71-72
*73-87
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 03-12-2018, 12:06 PM   #2
davepl
davepl's Avatar
Re: 71-72 center link 1/2, 3/4 ton difference?
So far as I remember they are different. I installed 1971 3/4 ton front brakes on my 1970 and used the donor centerlink, which I think you should probably do as well...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-12-2018, 12:43 PM   #3
randy500
71-2 3/4t center link is the same as 73-up 1/2 and 3/4t
71-2 1/2t center link is different from above center link.
randy500 is offline   Reply With Quote
Old 03-13-2018, 10:11 PM   #4
threeonthetree
Okay what I have is 71 1/2 spindles
And a 71-72 3/4 center link tie rods and drag link.
Is there anyway to make this work if I got a different steering box off of a 73-87?
I was planning on getting the 71-72 center link and using a 71-72 ball joint kit with tie rod ends and ball joints drag link ext.
Otherwise I’d see if I could get 73-87 parts such as spindles and then use this center link.
1969 c10 AKA SIN
1985 SSWB TRAZER
