03-16-2018, 08:45 AM | #1 |
Identify - Year / Model
Have inquired w/owner, no reply yet.
Do you recognize the year and model of this dump truck ? I suppose the cab is a bit larger than a standard 1/2T, 3100. ? Appears the 3100 is well suited to fit an S10 chassis. Would this cab be more suited to fit on a 79 K10 chassis ? Ever seen such a project undertaken ? Thanks. |
03-16-2018, 09:09 AM | #2 |
Re: Identify - Year / Model
This one looks similar.
Listed as a 56 - 4400. Trying to imagine one of these on the K10 |
03-16-2018, 10:47 AM | #3 |
its a 4400 or bigger, for sure. the 1/2 ton front end will fit if you have one.
here is a guy building a very nice 1/2 ton on a K20. http://67-72chevytrucks.com/vboard/s...d.php?t=726477 for what its worth, the 1/2 ton does not fit an s10 very well unless you stretch the front wheel track significantly. I put a 65 swb on an s10 and widened the control arms 4 inches per side.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-16-2018, 10:54 AM | #4 |
03-16-2018, 11:41 AM | #5 |
Why not just put the 4400 cab on a stock 1/2 ton 3100 frame? Plenty of them available and kits to upgrade to IFS.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-16-2018, 12:12 PM | #6 |
probably a spartan 1.5-2 ton: same cab, doors, grill and hood as 3100 thru 3800
the frame/suspension is heavier and the fenders are wider and have a bigger wheel opening next up is the viking 2.5 ton and up
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-16-2018, 12:17 PM | #7 |
The truck you are looking at should be a 57 with the ribs on the hood.
If you want to go 4x4 it should fit pretty well on the 77 K 10 chassis outside of the "normal" frame swap issues. There are a couple of them in this area on K 20 chassis that have been running around for years. If you are going 4x4 I'd leave the clearance lights on top of the cab and run the big truck bumper. Give it that serious get er done look.
03-16-2018, 02:38 PM | #8 | |||
Thanks. Might go look at it over the weekend. Thanks again guys. |
03-16-2018, 05:47 PM | #9 | |
most frame swaps end up sucking time, money and relationships down the drain they languish in the shop and eventually end up on craigslist priced not to sell
03-16-2018, 06:09 PM | #10 | |
Looked like far more successes than failures on the forum here. Probably just a passing fancy anyway. Our stock 54-3100 and original 39 Master 85 are probably enough to keep up with anyway. Seemed like a doable project tho ... initially. Thanks for the warning. |
03-17-2018, 12:11 PM | #11 | |
