03-17-2018, 02:54 PM | #1 |
Ez wiring harness to 86 factory tail light harness HELP!!
Finishing up the wiring on my 86 c10
I'm using the ez wiring harness. My truck has the taillight harness with a four wire plug No matter how I connect any of the wires. My brake lights will not light up. I was told I had to splice directly to the bulb sockets. But I would prefer to keep the original harness. Has anyone ran into this same problem? |
03-18-2018, 09:46 AM | #2 |
Re: Ez wiring harness to 86 factory tail light harness HELP!!
Sounds like a ground issue. Do you own a power probe?
03-18-2018, 10:44 AM | #3 |
If you are referring to the rubber 4-wire mating plugs-those are obsolete and nobody reproduced them-this is why I use weatherpack 4-cavity square connectors on my lighting harnesses. You have to combine the grounds to a single grounding ring and the rear lighting circuit grounds to the body behind the tail light housings. And, your box should have a grounding strap from a floor support brace to the frame as well.
03-19-2018, 09:00 AM | #4 |
All the grounds are in place in the factory locations. And the four wire connector is a weatherpac type connector
There's a yellow, brown, light green and a dark green The new harness has yellow, green, brown and orange. |
03-19-2018, 09:33 AM | #5 |
Yellow and dark green are your turn signal +12V leads, brown is spliced to all other browns and light green is your backup +12 lead. Orange is NOT part of GMs’ tail light wiring schematic that I’m aware of. Are the black leads from the turn signal socket going to chassis ground then?
03-19-2018, 03:12 PM | #6 |
Alright that clarified things a bit. I'll give it a shot again tonight and post back with the results
03-19-2018, 03:25 PM | #7 | |
Msgt USAF Ret
Here's a couple of diagrams that show the wiring of the turn signal switch and they also don't show an orange wire. There are additional wires added for the courtesy light and key in buzzer, but the main wiring is the same as it was back in the sixties. 86Chevy another 86 chevy and here's an 88 diagram. The new harness may have the orange wire as a substitute but it should be stated as to what it is.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-20-2018, 05:37 AM | #8 | |
I did forget to mention the orange wire is for the third brake light. Since I don't have one, I can just tape it up and leave it within the harness I don't have any dome lights or courtesy lights anymore as well so it helps simplify things a bit. I haven't had a change to tinker with it but I'm hoping to have everything finished up soon |
03-26-2018, 07:49 AM | #9 |
Little update. Rear lights work now. As well as brake lights. However the driver side lights seem a lot dimmer than the passenger side
03-29-2018, 01:21 AM | #10 |
Bump. Tinkered around with the tail lights.
I now no tail running lights. Brake lights work, however driver side lights are dimmer than the other Turn signals world but same thing with being dimmer than the passenger side. I'm completely lost. |
03-29-2018, 09:10 AM | #11 |
At this point I’m willing to bet you’ve got excessive resistance due to corrosion within the wire jacketing itself-common problem with “customer” added trailer harnesses prior to you owning the truck.
03-29-2018, 09:28 AM | #12 | |
I tinkered around with the lights this morning. I made a separate thread about it. When my switch is pulled out to the first detent for parking lights everything works Then I pull the switch all the way out and I have no tail lights. But the turn signals still work. |
03-29-2018, 10:10 AM | #13 |
Did you check both grounding rings behind LH and RH tail light lenses? Use a test light and verify voltage on the brown wire in the 4-wire firewall bulkhead connector-if its good, go check any brown wire at the rear-this is the power wire for the running lights. After this we can troubleshoot the ground circuit.
03-29-2018, 11:37 AM | #14 |
Ok just used a test light connected to a ground on the driver taillight housing.
Test light didn't light up at all. The two brown wires are labeled right tail park and left tail park. And there's a short one for the license playe |
03-29-2018, 11:45 AM | #15 |
No power coming out of the dark purple and brown wire off my new headlight switch I just put in.
When we did the headlight switch portion of the wiring we jumped the purple and brown together. And those to go to the two brown wires are labeled as left front park. And left tail park |
03-29-2018, 05:16 PM | #16 |
Alright guys thanks for all the good info!
I ended up calling EZ wiring and within 2 minutes of being in the phone I had taillights For anyone having any type of issues, at the headlight 7 pin switch, you need a jumper from the switch power, to any of the orange wires. Made the jumper and everything works fine |
