Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-24-2018, 07:02 PM   #1
AZ 67 C10
AZ 67 C10's Avatar
Converter stall for turbo 4l80
Im looking for recommendations on what stall/converter for a 6.0 4l80. Going to be a s475-ish turbo running around 10lbs and using foot brake to stage. Trans is currently getting a refresh and 2wd tail shaft and housing so I want to get a converter for it now too. Built 12 bolt with 3.73 gears and trutrac. I've seen people going around 3000-3400 for stall, i'll be hitting the track often but still will see the street.
AZ 67 C10 is offline   Reply With Quote
Old 03-25-2018, 10:39 AM   #2
Trackman101
Trackman101's Avatar
Re: Converter stall for turbo 4l80
3400 minimum for that set up. Put a transbrake in it too
Trackman101 is offline   Reply With Quote
Old 03-26-2018, 06:55 AM   #3
PGSigns
PGSigns's Avatar
For the last ten years or so I raced I ran Hughes converters. They are in Phoenix. Look up Hughes Performance and go see em. Let them build you one.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-29-2018, 09:18 AM   #4
dangrebel
What cam? that will have the most effect on converter choice.
dangrebel is offline   Reply With Quote
Old 03-29-2018, 11:18 PM   #5
AZ 67 C10
AZ 67 C10's Avatar
Thanks for the input guys, i'll give hughes a call too and see what they say.
Haven't choose a cam yet, and I didn't realize it would make that big of an effect on converter choice. I'll start looking into that now too.
Old 03-30-2018, 12:38 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cam is gonna have less to do with it on a boosted setup. More stall means more "slip" i.e. more time/rpm while on the footbrake. This means you can affect how much boost is being built off the line, relative to where your turbo spools.
FWIW, there are people out there that run stock 4l80e converters (~1800rpm) on boosted motors and claim its ideal. Most of the stuff I see runs the 32-3600rpm range for turbo or P1/D1 cars. There's a certain amount of balance between turbo size, stall speed, and spool time/boost pressure.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-01-2018, 08:09 PM   #7
AZ 67 C10
AZ 67 C10's Avatar
I'm familiar with stall, just all my experience is in the diesels. My rpm is much lower but boost much higher when i'm staging, quite the opposite as a gas engine I'd imagine.
I just couldn't see the stock converter being the best option especially since its boosted. Then again this is all new to me so I have no idea. My plan is to run around 10-12lbs. I'll keep doing some research but thanks for the info.
Old 04-11-2018, 02:37 PM   #8
vin63
It's Better With Nitro
vin63's Avatar
Most of the reputable torque converter builders will work with you on your specific application. They will ask about your combination, etc. The converter builder who built all of mine for my Super class car and other hot rods, had me complete a worksheet that details everything about my engine combo, vehicle weight, rear gear, tire sizes, dyno results/printout (if any) etc.
I just had a billet converter built for my 4L80e that I had to complete the worksheet for the builder. It turned out to be around 3400 RPM based on my combo and what my operating goals are for my truck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-15-2018, 06:27 AM   #9
BossHogg69
motor exploder
BossHogg69's Avatar
Man, it's a shame you have to cover that converter up with a bellhousing!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-20-2018, 05:59 PM   #10
1Bad72C10
interesting i would have thought it to be less but im in the same boat as the original poster. new to the gas game just started building my set up again hoping to get some time home to actually get in the shop and do some work and take some pics for everyone here. im building a 540 tt truck with a 4L80E stage 5 from rossler 3.00 gear and a 29x15x20 mickey thompson rear tire and plan on running around the streets on pump gas with no more than 15 lbs of boost so if your at 3400 i'm kind of scared where my stall will be at. I guess i need to call pro torque converters and see what they say as i'm getting close to recieving my transmission and motor
1Bad72C10 is offline   Reply With Quote
