Old 03-26-2018, 11:44 AM   #1
atvtrailrider
Who should I buy a short block from?
I have a gen III LQ9 with a spun cam bearing. Thinking of buying a new LQ9 short block and moving my heads over.
Who would you recommend buying a short block from? ATK has one for $2399 free shipping?
Thanks for the input.
atvtrailrider is offline   Reply With Quote
Old 03-26-2018, 12:42 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Who should I buy a short block from?
shortblock for 2399? wow...I'd just get a complete pullout engine....and start over..or rebuild what you got....spun cam bearing is usually not detrimental to a block...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-26-2018, 04:41 PM   #3
atvtrailrider
Machine shop said $500 to line bore and fix can bearing.
Now add clean and hone and deck. Then new pistons, rings, main bearings and installation.
I think I end up more than just buying a short block.
Old 03-26-2018, 04:45 PM   #4
mongocanfly
Post Whore
did you spin a cam bearing or a crank bearing?......
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-26-2018, 08:42 PM   #5
atvtrailrider
Cam bearing
Old 03-27-2018, 10:44 AM   #6
davepl
davepl's Avatar
Wow... I wonder how that happens. Debris in the oil that gets into the bearing? Just seems so unlikely that a cam could rotate a billion times over a couple of years and then one day just grabs the bearing!
Why would you need new pistons and all of that? LS motors run a long time... you'd think they could tear it down, fix the cam journal and bearing, and put it back together.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-27-2018, 06:13 PM   #7
atvtrailrider
Probaly poor maintenance but according to machine shop it is pretty common. I think truck it came out of had 170,000+ miles.
Old 03-27-2018, 07:15 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
https://www.summitracing.com/parts/nal-12679002
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-27-2018, 07:18 PM   #9
Clyde65
Clyde65's Avatar
https://www.summitracing.com/parts/nal-19353405
Clyde65
Rebuild of Clyde
support our troops!
Old 03-27-2018, 07:51 PM   #10
7 Devils
7 Devils's Avatar
Wow, that seems crazy to me. My 06 LM7 (5.3) has 258k and still runs awesome. I tend to agree with Greg though. I've pulled many of the LS based truck motors from parts yards and slapped turbos on them (10-14 psi) with very little modification and had them go several seasons.
ATK does have pretty good reputation and customer service though. Dealt with them commercially off and on for years
Dan
Forgive my typos, big fingers and little Android digital keyboard....what a mess
06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it.
67 El Camino Custom 300 Deluxe. In progress.
55 GMC 371 2 1/2 ton. Upcoming project.
7 Devils is offline   Reply With Quote
Old 03-28-2018, 09:10 AM   #11
atvtrailrider
Originally Posted by Clyde65 View Post
If I bought the bare block I assume I could move everything over? Reuse pistons? Just new main bearings and and rings and assemble?
Old 03-28-2018, 10:45 AM   #12
sprint_9
sprint_9's Avatar
Depends on how much debris went through the oil and how damaged everything is.
I would think at minimum you will need a cam and lifters, and all bearings/rings if swapping blocks. From there you might need pistons if they are scored and crank work if it is scored or damaged, which at 170000 plus miles with poor maintenance the chances of both of those is pretty high.
I'd tend to think at this point you might be further ahead to use you engine as a core at a salvage yard and get a completely different engine.
sprint_9 is offline   Reply With Quote
