03-28-2018, 05:16 PM | #1 |
Interior lights stuck on
My 89 Suburban's interior lights won't shut off. I tried slamming all the doors, messing with the door switches on every door but nothing seems to work except removing the wire from the fuse block. Also the rear passenger doors have never operated the interior lights.
Not sure where the issue is, but hitting a really rough road usually shuts them off temporarily before some more bumps makes them come back on. I'm thinking there is an intermittent short somewhere, but don't know where to look. Any suggestions?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
03-28-2018, 07:13 PM | #2 |
Re: Interior lights stuck on
Turn the headlight switch knob to the right a little.
04-02-2018, 01:04 AM | #3 |
Forgot to mention, it doesn't matter where the dimmer knob is. Turning it all the way down doesn't turn off the interior lights.
04-03-2018, 12:19 AM | #4 |
Maybe just try a new headlight switch?
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
04-03-2018, 12:30 AM | #5 |
Post Whore
I'd be searching for a necked or pinched wire...the door switches make the ground side of the wire circuit...if one of those wires is pinched or missing some jacket and grounded, the light will stay on....^^^but could also be the switch^^^
04-03-2018, 09:52 PM | #6 |
That's what I was thinking. Was hoping someone on here had the same problem and there was a 'trouble' spot.
04-04-2018, 03:27 PM | #7 |
Yea, I'd check out the pin switches. Maybe change them out to new ones. I think they are reversed grounded or something. Just a little strange as I recall.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
