Old 03-29-2018, 09:47 AM   #1
Dallen17
203 transfer case swap with a 205
My 203 transfer case went out on my 79' Chevy k20. Actually it exploded and now my daily driver is sitting In my garage. After doing some research, I have decided to swap the 203 with a built 205 tcase. Does anyone have any advice on what I'll need or anything that can help is appreciated!
Dallen17 is offline   Reply With Quote
Old 03-29-2018, 05:07 PM   #2
sweetk30
sweetk30's Avatar
Re: 203 transfer case swap with a 205
if the trans is th400
shifter assembly is different .
adaptor is different .
output shaft in trans is longer . 203 is shortest . the rest are longer for each combo .
driveshaft lengths will be different .
otherwise its a fairly straight forward swap .
let me know if you scrap the 203 . drop me a pm .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-29-2018, 07:36 PM   #3
wildwilly4x4
If your trans is a th350, then a 205 will be a bolt on affair... If you're running a th400 a trans rebuild will go along with the swap just fine. Doesn't cost too much to just throw in a banner kit when you swap outputs provided your trans is working fine now.
wildwilly4x4 is offline   Reply With Quote
Old 03-29-2018, 10:01 PM   #4
sweetk30
sweetk30's Avatar
yes forgot to post that info on my post . fixed it .
