Old 03-31-2018, 01:18 PM   #1
Chilly178
Chilly178's Avatar
Correct flywheel for 5.7 vortec?
Planning on doing a 5.7 vortec swap in my 72 C20. Has a SM465. Will this flywheel work? https://www.summitracing.com/parts/n...stionsanswers/
Chilly178 is offline   Reply With Quote
Old 03-31-2018, 04:08 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Correct flywheel for 5.7 vortec?
I believe so
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-31-2018, 07:05 PM   #3
Mike C
Mike C's Avatar
That is the correct flywheel for an L31 Vortec motor. Smaller bolt pattern with counterweight for the one piece main seal crankshaft.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-31-2018, 09:44 PM   #4
Chilly178
Chilly178's Avatar
Summit has this as a warning "Performance and SFI-approved flywheels must be used with performance clutch discs only. Use of a stock-style clutch disk with a performance flywheel will often result in insufficient operating clearance between the disc hub and flywheel bolts." Does this affect what kind of clutch I can use with this flywheel?
Old 03-31-2018, 10:21 PM   #5
Mike C
Mike C's Avatar
I've not seen that sort of language used before when talking clutch and flywheel clearance. But performance type clutches aren't much more expensive that stock ones. Or just run a performance disc with an OEM pressure plate.
44 Willys MB
52 M38A1
64 Corvette Coupe
