Old 04-09-2018, 12:31 AM   #1
ryanv70c10
How to tell if truck or van tilt
I'm going to go look at a tilt steering column tomorrow and I want to make sure I'm not buying a van column how can I tell the difference thanks in advance.
ryanv70c10 is offline   Reply With Quote
Old 04-09-2018, 12:55 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: How to tell if truck or van tilt
Top bottom in picture below.
- Motorhome
- Truck
- Van. The fitting at the end of shaft comes off and the shaft is splined like the other 2.
As you can see, the truck tilt has the neutral safety switch in a different location, the motorhome tilt has a bend in the part the auto transmission linkage attaches to, and the van has a longer shaft.
FirstOwner69 is offline   Reply With Quote
Old 04-09-2018, 12:55 AM   #3
sixty-eight shorty
sixty-eight shorty's Avatar
I did a quick search on the forum's search engine and came up with this picture.
sixty-eight shorty is offline   Reply With Quote
Old 04-09-2018, 01:08 AM   #4
ryanv70c10
ok guys thanks for your help! Looks easy enough to spot the differences...
Old 01-31-2023, 11:51 AM   #5
Auctioneerhere
What spline are these columns? Thanks
Auctioneerhere is offline   Reply With Quote
Old 03-10-2024, 01:36 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
- Motorhome
- Truck
Great info and thanks for posting. Just a question about the motorhome tilt in the picture. When u say motorhome tilt do you mean like a 67-72 Winnebago motor home with a GM powertrain or the cab & chassis with motorhome body added.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-10-2024, 02:38 AM   #7
Richard
Did not get any replies when I asked and ended up ordering the wrong joint for my steering. Going to help you out. My stock tilt is 3/4" x 36 spline.
Richard
